General Information
» Upgrades (non engine related )
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Gauge sender unit/question.
VW RABBIT TRUCK ( CADDY ) REAR COILOVERS
Diesel Tach Idea.
Clifford IntelliStart on a CE2 MK2 GTD
How do you mount a strut bar?
Tyre size dilemma.....
suspension upgrade questions
IC mounting idea.
All MKII seats are not the same
4 door Caddy
register a homemade vehicle?
24" inch RED ( 1/0 AWG ) SAE Battery Cables SIZE : DIAMETER 1/0 GAUGE
Jetta A2 shifter upgrades
K&N Airflter for the AAZ ( airbox replacement )
Non VW seats for a Caddy
Using a gas tach / cluster w/ 1.6 N/A diesel (how to wire tach, "w" terminal?)
OPTIMA BATTERY & BILLET BATTERY CLAMP
lift a 90 Jetta
The sprocket for the Intermediate shaft
CADDY AXLE FLIP ( LOWERING OPTION ) 2'5 drop
MK1 Square to round headlight question.
MK1 S/S BRAKE LINES & Rear Axle / Master Cylinder ( hardlines )
G60 clutch in 1.6td?
How much play in front suspension is normal?
VW Rabbit Truck Rear leaf spring Insert ( bushings )
Temp Caddy Wheels
fender mirror.
Fuel Tank Caddy / Rabbit Truck
Can i Re-scale a mk3 TDI cluster Gauge?
making an emblem from the "turbo" on audi5000 intake mani.
Anyone have access to part number for 81 Truck 1.6 A/C Radiator ?
Roof antenna - where to drill?
heater core question
Ignition Lock Cylinder - 85 Golf - How do I remove one?
What shifter parts 4 to 5 speed for Rabbit.
I had a crazy thought, Ideas please.
Bigger upper spring perch for new rear springs? (Rabbit)
PMA's (permanent magnet alternators) up to 50% more efficiency :)
What tranny should I use with the AAZ in a MK1 Rabbit?
MKII Jetta Manual Steering- MK II Scirocco U-Joint Fit?
GAUGE DECALS: Speedo, clock, tachometer, Fuel, Temp
BRAKE BOOSTER OHC AND OTHER PARTS
Vanagon Question-Power Door Locks & Washer/Wiper Switch
winter is coming aux heater in a MK1
Mk2 speaker grill removal?
header on a 1.6
Creating a W terminal on alternator.
color critique
Window crank handle clearance
Suggestions welcome - washer fluid bottle location
