Author Topic: How much play in front suspension is normal?  (Read 3566 times)
January 16, 2010, 07:44:01 pm
clbanman
  • 705
    Cambridge, Ontario
« on: January 16, 2010, 07:44:01 pm »
I have what I suspect is abnormal play in the front end of my car.  I checked play at the rubber bushings on the front control arms, but don't know what is normal/acceptable.  There is no visual damage to the bushings - i.e. missing rubber, obvious breaks, but when I put a pry bar between the rear of the control arm and the anti-roll bar, I could move the control arm around over 1/4 inch, which I think is excessive.  Can anyone confirm what is normal and acceptable?
Calvin
91 VW Golf 1.6NA 5spd
Reply #1January 17, 2010, 08:24:16 am
  • 1739
Re: How much play in front suspension is normal?
« Reply #1 on: January 17, 2010, 08:24:16 am »
If you are talking about the horizontal bushings at the rear of the tables then taking a pry bar  between the table and subframe ,you should be able to move the table ,but without excessive pressure ,not be able to make the table "knock " against the subframe. If it's the front bushings, they should be pretty tight, no more than some slight play.
Reply #2January 19, 2010, 09:08:17 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #2 on: January 19, 2010, 09:08:17 am »
Yes, I am talking about the rear bushings on the front lower control arms.   I can move the control arm both vertically and horizontally with reference to the ground.
Calvin
Reply #3January 19, 2010, 05:29:43 pm
  • 1739
« Reply #3 on: January 19, 2010, 05:29:43 pm »
If you can move them just by rocking them by hand, they are toast. If it takes a good size pry bar or big screwdriver, then some play is okay. With a prybar, generally you shouldn't be able to move them enough to touch the top or bottom of the subframe when it sits in.
