Author Topic: Can i Re-scale a mk3 TDI cluster Gauge?  (Read 3874 times)
December 20, 2009, 05:57:12 am
CrAzY_DrIveR
  • 16
    • MK1 TDI
« on: December 20, 2009, 05:57:12 am »
I am trying to place the electronic parts of my tdi cluster into my '80 rabbit old cluster to make something like an hybrid.
How can i re-scale the rpm gaugeto make more space to fit the temp and fuel in the same gauge?
Is it possible to program the cluster?
I have read that if i put a gasser tacho on my tdi that the needles would work normally so it would probably solve my problem by reducing the scale used by the tdi with a smaller rpm range.
For parts i have the tdi cluster 220km/h and 4750 rpm redline
GTI cluster 220km/h and 6200 rpm redline
and without MFA another cluster up to 200km/h
to look like tis lupo cluster
Thanks!
« Last Edit: December 20, 2009, 08:30:16 am by CrAzY_DrIveR »
'80 Rabbit TDI Project - www.mk1tdi.blogspot.com - ARL PD300 in progress...
'89 BMW 324td
Reply #1January 05, 2010, 08:05:08 am
drrtybyl
  • 146
Re: Can i Re-scale a mk3 TDI cluster Gauge?
« Reply #1 on: January 05, 2010, 08:05:08 am »
That's a cool idea for preserving the 2-hole design.  Are the temp and fuel gauges too large to work with as-is?
I'm about to dive into fitting the tdi cluster to mk1 dash as well.  I may end up just butchering the stock dash and leaving the tdi intact.
« Last Edit: January 05, 2010, 08:37:15 am by drrtybyl »
'79 Rabbit Diesel L
'94 Chevy 2500 6.5TD
'96 BMW 318ti
Reply #2January 05, 2010, 10:18:02 am
CrAzY_DrIveR
  • 16
    • MK1 TDI
« Reply #2 on: January 05, 2010, 10:18:02 am »
Yes i really like the 2 hole design. Temp and fuel gauges motors are bigger than tacho and speedo, it will be a tight fit. The hard part is to make a PCB to fit the two lcd's and then solder the wires to the tdi original PCB.
People ussually take the easy way, just fitting the tdi cluster. Doesn't look bad but doesn't look stock either.
'89 BMW 324td
Reply #3January 05, 2010, 12:29:55 pm
CrAzY_DrIveR
  • 16
    • MK1 TDI
« Reply #3 on: January 05, 2010, 12:29:55 pm »
my scanner takes wonderful pictures :D
'89 BMW 324td
