Author Topic: Clifford IntelliStart on a CE2 MK2 GTD  (Read 2703 times)
March 15, 2010, 09:56:40 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« on: March 15, 2010, 09:56:40 am »
Anyone done it?
Just got a Clifford Avantgard 4 cheap, had a concept 600 years ago on my old GTD, but it wnt wrong so I changed it to a Toad Ai606 but the siren has died so I got the Avantgard set up this has Black Jax same as my old system and has IntelliStart IV now I'm fairly sure it got a tach signal off the green wire going to my clocks on my old GTD but both manuals say I need a device that clips on the altenator to see RPM signal  ???
Can I just connect it to the tach wire or do I need to get an optional Alternator sensor?
Cheers
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #1March 24, 2010, 01:20:03 am
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: Clifford IntelliStart on a CE2 MK2 GTD
« Reply #1 on: March 24, 2010, 01:20:03 am »
since the tach is run from the alternator on the diesel, the wire that drives your GTD clocks is the signal you need
'91 Golf Cabrio 1.9TD
