Author Topic: What tranny should I use with the AAZ in a MK1 Rabbit?  (Read 5684 times)
November 18, 2009, 10:34:03 am
Tag-Along
  • 25
« on: November 18, 2009, 10:34:03 am »
Hello there,
This is my very first post on here!  I am NEW to the diesel scene and have a question for you all.
I am wanting/planning on putting an AAZ in my 1981 Rabbit Diesel.  What 5 speed transmissions can be used with the AAZ?  I have heard that the O2O can be used.  I currently have a 4K, can that be used?
Sorry if this may be a stupid question, but I really don't know squat about diesels...at this time.
Reply #1November 18, 2009, 10:58:29 am
spencebm
  • 686
Re: What tranny should I use with the AAZ in a MK1 Rabbit?
« Reply #1 on: November 18, 2009, 10:58:29 am »
i think most 020s will bolt right up with the right parts.  don't use a 4 speed.  I have a 1.9 with an ACN code 020 and it is great!  Low rpm on the interstate.  Someone else should be able to tell you more in detail what you need.
Ben Spencer
Reply #2November 18, 2009, 11:46:58 am
« Reply #2 on: November 18, 2009, 11:46:58 am »
http://www.scirocco.org/gears/
This site has all the 020 (most all of them) gear ratio's find out what size tires your using and punch in the numbers and see what trans gets you what speeds on the highways lol.
FN, FF, FH, FJ (most from '81)    FD 3.89 1st 3.45 2nd 1.94 3rd 1.29 4th 0.91 5th 0.71 Very desirable for a torque monster like a 1.9
Reply #3November 18, 2009, 12:28:36 pm
GEE-BEE
  • 1604
« Reply #3 on: November 18, 2009, 12:28:36 pm »
YOU WILL NEED A 5 SPEED GEARBOX MOUNT IF YOU DONT HAVE ONE ?
My 81 caddy had a 4 speed, total mileage since new 35k
Mine is a CHD  Trans , ( std on AAZ )3.66 with a .074 final
I had it overhauled with a pelloquin limited slip, added 100 mm drive flanges at overhaul and 16v axles ( new )
There is a ATH 5 Speed ( 4t ) on ebay , buy it now 299.00 with 100 mm drive axles, 3.67 with a .075
it will bolt right up to the AAZ, get a new clutch assy before install
let me know what you are doing and I can give you some help !
Gee-Bee
[email protected]
ebay I.D.290371152879
ship it fed ex ground
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4November 19, 2009, 10:08:38 am
« Reply #4 on: November 19, 2009, 10:08:38 am »
ACN 5 speeds are alot easier to find and are layed out well for a diesel. out of econo box jettas.. i swapped my AUG out for one and it rocks... cruisin RPM dropped almost a full 800 rpms.
Reply #5November 20, 2009, 04:39:37 pm
lux
  • 5
    • djk
« Reply #5 on: November 20, 2009, 04:39:37 pm »
Is there any concern with using a 1.6NA transmission with a mildly tuned AAZ in terms of strength?  Would one be better off using the tranny from the AAZ?
Reply #6November 21, 2009, 11:33:38 am
« Reply #6 on: November 21, 2009, 11:33:38 am »
no, not really. an 020 is an 020. the gears inside are different tho.
Reply #7November 21, 2009, 07:06:52 pm
rallydiesel
  • 1880
« Reply #7 on: November 21, 2009, 07:06:52 pm »
It's always a good idea to replace the ring gear rivets with bolts if you have the resources. That's the weakest part of the 020.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
