View full version: Upgrades (non engine related )
« 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 »
  1. volfenhag
  2. Your next set of wheels...
  3. More Jetta Questions
  4. Anybody got rid of their brake proportioning valve
  5. VDO center console tachometer!
  6. MKI TO G60 BRAKES ( Calipers and rotor's )
  7. Mk1 Caddy equivalent size for tonneau/canapy
  8. How to remove speedo cable drive gear?
  9. Cluster Upgrade
  10. DIY: Tail light tinting
  11. Replacing vent window, can I do it myself?
  12. Aleternator Upgrade
  13. transmission code
  14. POR or Glass First ?
  15. ETKA Question (large photo, beware of size 56kers)
  16. Do you have to cut towers to install Koni Sport Shocks in rear of MKII?
  17. hid's in mk2
  18. brakes
  19. Decent standard tyres Golf A2 or Mk2
  20. HID's in a MK1 (yes i have searched)
  21. Need all new heavy duty suspension on a budget--recommendations?
  22. 90 to 100 axle swap
  23. Rear Spring Questions Can I use two springs on one shock??
  24. Exhaust Temp Gauge Positioning
  25. Speakers in MK2 Jetta
  26. Rear disk Brake conversion
  27. Son of Awright, I've had it w/these Alt/tens pulleys align! Solar anyone?
  28. Vanagon Diesel Bell housing onto late model Type IV aircooled trans
  29. Neuspeed sport springs for a MKIII work on a MKII?
  30. Cheap and easy A1/Mk1 Brake Upgrades, Would you guys be interested?
  31. Awright, I've had it w/these #$**&*! Alt pulleys Solar anyone?
  32. Can I Run 16" Low profiles on my 1990 Jetta IDI?
  33. lill help
  34. mk2 springs on the front of my mk1
  35. Lowering a Rabbit
  36. HID kit
  37. upgrade your mk2 golf headlights
  38. Jom coilovers any good
  39. 1990 Jetta 1.6 IDI, Bilstein vs Boge or what else?
  40. Diesel Purge My Old Friend
  41. muffler suggestions?
  42. child seat upgrade......recaro stylee
  43. 5 speed trans for a 4 speed 1.6 N/A (that will suit an AAZ as well)?
  44. Passat coils into an mk3
  45. New paint = time 4 POLL!
  46. AAZ motor mounts upgrades?
  47. $50.00 Paint job
  48. Sunroof seal
  49. aaz into a caddy down pipe
  50. Mk2 coils into Mk1
