Author Topic: 5 speed trans for a 4 speed 1.6 N/A (that will suit an AAZ as well)?  (Read 3704 times)
July 16, 2009, 04:00:51 am
Pre95
  • 81
I have been thinking I'd like to start sourcing all the parts for a 5 speed swap in to my 81 1.6 N/A, but am unsure which trans would be suitable for both the low horse 1.6, and a little more giddy-up AAZ.
I know I will need all the shift linkage, and likely will need caddy half shafts (100mm) and knuckles. Just not sure which trans would be good for the swap (gearing wise). Can a gas trans be used or is the gearing too short?
Also, which clutch would need to be used? The standard size for the 4 speed trans? Help appreciated  ;D
81 Rabbit Diesel - 250k and climbing :)
Reply #1July 17, 2009, 03:18:30 pm
Re: 5 speed trans for a 4 speed 1.6 N/A (that will suit an AAZ as well)?
« Reply #1 on: July 17, 2009, 03:18:30 pm »
I'm digging deep into the memory banks but when I put a 5 speed in my rabbit I didn't swap clutches. I (foolishly) took out my 4A tranny and put in a FF. The 4A has a better 4th then the 5th did in my new tranny.
You don't need to swap all the pieces of the shifter linkage, only 2 or 3 IIRC.
Gasser gearboxes are fine. Use www.scirocco.org/gears and fiddle with the different ratios that are available. Not all trannys bolt into a mk1 though however most of them are 90mm so you won't need to mess with the CVs.
Why does the tranny need to be suited for a 1.6na and AAZ?
Reply #2July 18, 2009, 07:24:27 am
lovinthedeez
  • 489
« Reply #2 on: July 18, 2009, 07:24:27 am »
no need to change the clutch.  I swapped out a GP 4 speed for an ACN 5 speed. It was a rabbit motor that I installed into a jetta using the gasser's original transmission.  took the motor/tranny out, unbolted the shatty gas engine, and the ACN slipped right on to the 1.6.  and on a side note, I think caddies have 90 mm axles.  100 mm axles only came on things that had 16v motors, I thought.
« Last Edit: July 18, 2009, 07:27:28 am by lovinthedeez »
Reply #3July 25, 2009, 01:51:52 pm
DieselSteed
  • 107
« Reply #3 on: July 25, 2009, 01:51:52 pm »
The FF trans came stock on my 1.6na Caddy (90mm flanges). I also used a FN bolted to my AAZ TD that went into a MK1 Jetta. I think there is only one linkage that needs to be changed, going from a 4 to a 5 speed but you can buy all new ones and new shifter bushings from Autohaus for about twenty bucks.
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
Reply #4July 27, 2009, 07:47:48 am
1outof5
« Reply #4 on: July 27, 2009, 07:47:48 am »
my '82 jetta (1.6 NA) came with a FF box and that was standard (as in never modified since factory release). The fith gear was actualy marked "E" on the gearshift nob. E for Economie.
Once you got the car to speed, slip it into 5th and cruise, not fast but reliable and cheap to run  ;D
