Author Topic: How to remove speedo cable drive gear?  (Read 3451 times)
October 06, 2009, 01:29:03 pm
overdrivegear
  • 120
« on: October 06, 2009, 01:29:03 pm »
Name says it all.  How do you remove the speedo drive gear from the cable?  I have to swap a red one for a white one.
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #1October 07, 2009, 08:02:41 am
Re: How to remove speedo cable drive gear?
« Reply #1 on: October 07, 2009, 08:02:41 am »
I just did this last weekend, swapped a white one out for a new red one.
All I did, after removing the cable/gear from the tranny, was give it a good yank and it popped right off.  There is a small c-shaped spring clip that keeps it locked on there, if you look at the new gear, you will notice a hole in the side of it, if the old gear will not easily come off, you can probably look through the hole on the old gear for the little clip, once you find it, rotate the gear until you see the ends of the clip and stick a small punch in the hole to compress the clip together, then it should pull off.  Though like I said, I didn't have to do this, it did not take much effort for it to come off.
Reply #2October 07, 2009, 09:50:40 pm
mystery3
  • 774
« Reply #2 on: October 07, 2009, 09:50:40 pm »
I just put a "dental" tool in the little hole and wiggled it around until it popped off.
