Author Topic: Anybody got rid of their brake proportioning valve  (Read 5830 times)
October 13, 2009, 07:39:22 pm
« on: October 13, 2009, 07:39:22 pm »
I am pretty much out of cash and do'nt mind rear wheel lock up, so has anyone done it? I just wanted to hear and see if anyone had trouble after it was gone. This is an MKII btw.
Reply #1October 13, 2009, 11:06:33 pm
Re: Anybody got rid of their brake proportioning valve
« Reply #1 on: October 13, 2009, 11:06:33 pm »
I think it would be rather exciting having the rear wheels lockup everytime you push the brakes :D......especially on a corner. ;D
One way of seeing how it would act is to pull the ebrake so it's dragging and then push the foot brake, it kinda fun 8)
Reply #2October 14, 2009, 05:21:37 am
« Reply #2 on: October 14, 2009, 05:21:37 am »
I have done that. I don't think they would lock up or lock up first since the rear are drums. I just wanted to know if anyone has done it and what the results were. I am going to do it unless someone says it kills the drivability.
Reply #3October 14, 2009, 10:23:53 am
Op-Ivy
  • 513
« Reply #3 on: October 14, 2009, 10:23:53 am »
I think the problem with not having it has to do with the amount of weight that isn't back there. It makes them a lot easier to lock up, thus the reason for having it. I wouldn't know how much of a difference it would make though.
Personally, I would leave it or replace it. It's there for a reason and AFAIK most new cars, if not all, have it as well.
Reply #4October 14, 2009, 01:51:44 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: October 14, 2009, 01:51:44 pm »
What? Spin totally out of control at 60mph on a wet tree lined road? Yup. :P Done that. ::) :o
 Once stationary, and unmaimed, I said "thankyou" and then I adjusted the proportioning valve so that it worked as it was intended. ::)
By all means experiment, but you might not enjoy the results for long. ;D
« Last Edit: October 14, 2009, 01:57:47 pm by smutts »
Reply #5October 14, 2009, 01:56:56 pm
smutts
  • 720
« Reply #5 on: October 14, 2009, 01:56:56 pm »
Mind you, with the way the rear wheel cylinders often leak on VW's, the point may be moot. ;)
Rumour has it that there are two different bore sizes for the rear brakes, depending on whether the car had a proportioning valve or not. If so, my money would be on the bigger bore with the cars with the proportioning valve. Anybody in the know on this one? ???
Reply #6October 14, 2009, 02:52:24 pm
« Reply #6 on: October 14, 2009, 02:52:24 pm »
Mine leaked and I am out of cash. I just want to run the brake line all the way back. I like the RWD and hard brakes in the back of most cars, but didn't know how much it affected these ones.
Reply #7October 14, 2009, 07:14:00 pm
maxfax
  • 2126
« Reply #7 on: October 14, 2009, 07:14:00 pm »
Slightly different beast here, but my MK1 does not have the load sensing prop valve..   Just the standard one mounted below the master cylinder..   It tends to lock the rear wheels rather quickley if I have the 100lbs of crap outta the back of it..  Especially when wet..
Maybe I'm thinking of something else, but aren;t those valves rebuildable with some o-rings???  Might be able to get away with a boneyard one for a while too..
Reply #8October 14, 2009, 10:26:03 pm
« Reply #8 on: October 14, 2009, 10:26:03 pm »
Maybe just swap in a non load sensing prop valve since they're (I think) more common, that'll at least keep you on the road........
Reply #9October 16, 2009, 02:42:40 pm
« Reply #9 on: October 16, 2009, 02:42:40 pm »
I wouldn't completely bypass the prop valve. You need to put in some sort of prop valve. I think early Golfs had the non load-sensing prop valve.
You increase your breaking distance by a fairly substantial amount, so be careful.
Reply #10October 16, 2009, 03:05:17 pm
truckinwagen
  • 1895
« Reply #10 on: October 16, 2009, 03:05:17 pm »
the other thing that valve is a residual pressure valve to make the self adjusting rear drums work.
83 Opel Kadett Diesel
Reply #11October 17, 2009, 08:18:24 am
smutts
  • 720
« Reply #11 on: October 17, 2009, 08:18:24 am »
Just to add to the confusion, my Blue 1991 Golf GTD has the prop valve as standard, my Red 1990 Golf GTD doesn't have a prop valve as standard. Both should be identical cars? Or not? ??? Both are factory standard with SB engine. ???
Reply #12October 19, 2009, 07:10:52 am
« Reply #12 on: October 19, 2009, 07:10:52 am »
Yeah I guess I could have specified that it is the load sensing prop valve. I hadn't thought about putting in a non load sensing one. Great idea. I bet any 60/40 from a disc drum setup would work and will be cheap from the yard.
Reply #13October 21, 2009, 04:54:03 am
« Reply #13 on: October 21, 2009, 04:54:03 am »
I would try and get one that matches your drum size, either 180 or 200mm and with the same engine if possible.
Reply #14October 22, 2009, 08:39:04 pm
SolarSteve
  • 264
« Reply #14 on: October 22, 2009, 08:39:04 pm »
Mine started leaking about 5 months ago.  The B-nuts were completely rotted off and Napa want $170 for a new one.  I just cut the lines, removed the prop valve and hooked the lines back up.  I took the car into our cul-de-sac that has all sorts of gravel on top of the pavement and was going about 30 MPH and slammed on the brakes.  The front brakes started to skid alittle first and the backs barely skidded at all.  All in all the car stopped very quickly.
I also have a 2 tank WVO system with the 15 galln tank in the trunk, so that may contribute a little to the rears not locking up.
Steve
91 Jetta 1.6 N/A
