Author Topic: MKI TO G60 BRAKES ( Calipers and rotor's )  (Read 3370 times)
October 09, 2009, 04:32:28 pm
GEE-BEE
  • 1604
« on: October 09, 2009, 04:32:28 pm »
I purchased the Ebrake cable and Caliper adapters to install a set of G60 calipers and rotors from a Corrado,
( GMAN ) [email protected]
I'am changing the brakes pedal assy from a MKII since I"am doing a new 25mm master cylinder and new Brake booster
I got everything I needed from a wreck 400.00  ( seats included )
I wanted new stuff like the master and booster thou...
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1October 18, 2009, 11:54:35 am
Jettagli16v
  • 344
Re: MKI TO G60 BRAKES ( Calipers and rotor's )
« Reply #1 on: October 18, 2009, 11:54:35 am »
I dont entirely understand this post.
Are you putting the Corrade G60 front brakes on the back of a mk1?
And where's the question?
I am familiar with the G60 (Corrado, not to be confused with the Girling 60 calipers from an Audi)
brake upgrade for Mk2/Mk3 4 cylinder,
but have little experience doing the kit on a Mk1.
(The reason I was looking here, I just got a full set of brakes for my 85 TD:
Corrado G60 fronts, and Mk3 rear discs...)
-Brad
Reply #2October 19, 2009, 08:43:29 pm
GEE-BEE
  • 1604
« Reply #2 on: October 19, 2009, 08:43:29 pm »
I was informing on how to install , I also had to do MKII pedal swapp since the different type of larger master cylinder
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
