Author Topic: Rear Springs  (Read 10497 times)
September 27, 2007, 03:00:51 am
Riverfurm
  • 122
Rear Springs
« on: September 27, 2007, 03:00:51 am »
I have an 86 golf two door that I use for work and carry about 100 Lbs. of tools. The rear struts are completely shot. So I want to replace the struts and springs. What springs that can carry the extra weight can I use????
Will springs from a Caddy work?
Thanks
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #1September 27, 2007, 07:10:29 am
g-spec
  • 289
Rear Springs
« Reply #1 on: September 27, 2007, 07:10:29 am »
If i recall correctly the caddy has a different suspension set up...i believe it has leaf springs in the back!!!!
Reply #2September 27, 2007, 09:33:24 am
Rear Springs
« Reply #2 on: September 27, 2007, 09:33:24 am »
100 lbs isn't much at all... i've loaded down my '86 jetta with 3 heavy set people (maybe 400 lbs combined?) in the rear, and then me and someone else in the front too...  damn that car was a pig... it just loved to haul heavy loads!!!
it had new shocks in the rear, but not sure which ones.  it did sit pretty low... i would recommend going with heavy duty shocks & springs from bilstein if you want it to last.
Reply #3September 27, 2007, 11:05:25 am
Rear Springs
« Reply #3 on: September 27, 2007, 11:05:25 am »
I won't even tell you what I put in my jetta :shock:
Anyways, passat rear shocks and springs bolt in (change the upper strut mount). They are more heavy duty and will give you an inch or two of lift
Reply #4September 27, 2007, 08:05:30 pm
akrallysport
Rear Springs
« Reply #4 on: September 27, 2007, 08:05:30 pm »
Umm, I had a Mazda 323 engine in the trunk of my Jetta for about 3 days. I probably have about 100lbs in spare parts and fluids right now.  :twisted:
It is possible that Passat springs may work... unless someone can say otherwise.
Reply #5September 28, 2007, 10:13:58 am
MacGyver
  • 245
Rear Springs
« Reply #5 on: September 28, 2007, 10:13:58 am »
The Parts Place in MI sells HD springs for the MkII chassis, and they work excellent. ~$100/pr front or rear.
Edit:
Link to previous discussion:
http://vwdiesel.net/phpBB/viewtopic.php?p=60011&highlight=#60011
Reply #6September 28, 2007, 05:52:55 pm
Riverfurm
  • 122
Rear Springs
« Reply #6 on: September 28, 2007, 05:52:55 pm »
Called yesterday. Very helpfull sold me some HD shocks and springs.
Reply #7September 28, 2007, 05:58:31 pm
Riverfurm
  • 122
Rear Springs
« Reply #7 on: September 28, 2007, 05:58:31 pm »
Quote from: "akrallysport"
Is there enough room for the girl and the frying pan :?:  If not let me know :D
Reply #8September 27, 2012, 06:27:16 am
JBG3
  • 227
Re: Rear Springs
« Reply #8 on: September 27, 2012, 06:27:16 am »
Edit:
id like to revive this thread, is The Parts Place still a going concern?  and is the topic above gone?
Basically, I have the same question, Ive got a VO tank out of a much larger and heavier car im considering installing, 18 gallons and filtration equipment, and I want to beef up the rear suspension to hold it up.
my questions are what year passat rear shocks, springs, and strut mounts do I need to fit a Mk2 4 door jetta, also 86? and are they heavier duty than the HD shocks and springs for a mk2 that The Parts Place apparently sell?
1986 1.6NA Jetta
Reply #9September 27, 2012, 09:15:09 pm
Re: Rear Springs
« Reply #9 on: September 27, 2012, 09:15:09 pm »
The topic probably still exists somewhere, but the link is the old style from before the crash. Unfortunately it also looks like a bad link so I can't pull it up. It is late though so I could be out to lunch
Reply #10September 27, 2012, 09:25:12 pm
bbob203
  • 1789
Re: Rear Springs
« Reply #10 on: September 27, 2012, 09:25:12 pm »
germanautoparts has hd springs for mk2 52.50 a piece. if not use vr6 b3 or b4 springs with 1 coil chopped off. or make a lift kit with some coduit couplers and an exhaust clamp works great...
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #11September 27, 2012, 09:35:25 pm
Re: Rear Springs
« Reply #11 on: September 27, 2012, 09:35:25 pm »
A hockey puck is a super easy way to effectively increase spring rate.
Reply #12September 27, 2012, 09:39:53 pm
bbob203
  • 1789
Re: Rear Springs
« Reply #12 on: September 27, 2012, 09:39:53 pm »
still need to try that one. right now im running the lift kit with the couplers clamped to the shock i carry over 500 lbs regularly with no issues. i need to trim them down though without load my car rides like a horse drawn carriage.
03 Jetta wagon TDi
Reply #13October 13, 2012, 12:33:34 pm
monomer
  • 414
Re: Rear Springs
« Reply #13 on: October 13, 2012, 12:33:34 pm »
Edit:
Agreed, I have a pair in my rabbit. Rides great and has never bottomed out.
www.michiganvw.org
Reply #14December 05, 2012, 08:51:18 am
JBG3
  • 227
Re: Rear Springs
« Reply #14 on: December 05, 2012, 08:51:18 am »
parts place still has the HD springs for the 86 jetta, item number on their website 2144.  Just ordered up a set
1986 1.6NA Jetta
