Author Topic: Need help with Caddy sway bar install; got pix?  (Read 3656 times)
June 23, 2012, 08:20:31 pm
sparkoid
  • 37
« on: June 23, 2012, 08:20:31 pm »
I bought an Autotech front swaybar for my 81 Caddy, along with aftermarket bushings and brackets.  The brackets seem a little flimsy to me compared to other stuff I've seen, and it's not clear how to mount this thing.  Anyone have pix of a Mk1 front swaybar installed???
Reply #1June 23, 2012, 08:26:26 pm
Re: Need help with Caddy sway bar install; got pix?
« Reply #1 on: June 23, 2012, 08:26:26 pm »
too bad its not a 82... 81 the brake/fuel lines are in the way... the rerouted them in 82...
control arms have 2 hols if replaced... none if stock.. ends go there..
rear control arm u shape brackets are the body mount for swaybar... you will find the brake/fuel lines are behind the arms and the bushing area for the bar will hit them... in 82 they moved that to the front of the brace they follow...
