Author Topic: A/C installation instructions for 1981 1.6 Turbo Caddy  (Read 3910 times)
May 25, 2008, 08:12:36 am
gilroygolfer
  • 1
« on: May 25, 2008, 08:12:36 am »
If anyone knows text or member contribution doc that could give guidance on this task, Id be very thankful.
1981 VW Caddy 1.6L Turbo w/ SAAB intercooler, GTI grill and spoiler, power steering and 4 wheel DB all around
Reply #1May 25, 2008, 10:12:50 am
« Reply #1 on: May 25, 2008, 10:12:50 am »
charging procedure or actually installing the compressor/lines etc???
Reply #2October 26, 2008, 07:10:13 pm
Krazy
  • 48
« Reply #2 on: October 26, 2008, 07:10:13 pm »
How about both?
Jack Carr
Mt. Juliet, TN
I drive a Clatterpillar 1.6 n/a
Reply #3October 27, 2008, 05:38:54 am
« Reply #3 on: October 27, 2008, 05:38:54 am »
i'll give you some tips/advice
do not let ANY and i mean ANY dirt get into the system.  use a non hydroscopic oil like that of duracool.  install a new receiver drier.  install viton o-rings on all lines if you can.  o-ring kits can be had from e-bay for fairly cheap.
do you think your missing lines?  don't know which ones go where?  the smaller diameter hose is the high pressure line going from a/c comp to condensor, then to evaporator.  low pressure (big hose) goes from evap to comp and most have this round cylindrical chamber somewhere in between.  i forget what its for...
