General Information
Upgrades (non engine related )
Gasser clutch on 1.6?
Topic: Gasser clutch on 1.6? (Read 4304 times)
December 11, 2008, 07:57:42 am
December 11, 2008, 07:57:42 am »
I've tried searching but come up with mixed results. I think I read that you can use the larger 8v gasser clutch in place of the 1.6D clutch. So basically all I need is the complete gasser setup, right? Flywheel, clutch, pressure plate? Or am I missing something?
Thanks,
'86 Golf N/A Diesel -->Wife's car
December 11, 2008, 09:20:52 am
December 11, 2008, 09:20:52 am »
Bolts right on.
I'm one of many using the larger gasser clutch on my diesel.
Pressure plate, clutch disk, flywheel is all needed.
You can run the 190 clutch disk with the 210mm clutch assy as well.
December 11, 2008, 11:18:00 am
December 11, 2008, 11:18:00 am »
Cool! Off to find a deal on a gasser clutch.
Thanks-
December 14, 2008, 10:08:06 am
g-spec
December 14, 2008, 10:08:06 am »
Im using a 8v disc with a 16v pressure plate and stock flywheel. Holds 40psi on my 1.9 IDI with t3.
December 14, 2008, 10:10:10 am
December 14, 2008, 10:10:10 am »
Just remember that the gasser flywheel may or may not have the critical timing mark at TDC.
December 14, 2008, 12:57:00 pm
madrogers
December 14, 2008, 12:57:00 pm »
the gasser flywheel i used on my 1.6n/a worked but the timeing marks where different then the diesel. i set the tdc with the idi flywheel and used the injetion dial guage to verify where i was and swaped on the gas flywheel and marked the tdc onto the gas flywheel for later use.
Mark
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
December 14, 2008, 11:39:09 pm
December 14, 2008, 11:39:09 pm »
apparently the diesel clutch springs are stiffer... something to think about!
December 25, 2008, 10:57:36 am
dieselherb1
flywheel
December 25, 2008, 10:57:36 am »
I noticed that one of the flywheels I have(could be gasser) is thinner-lighter any advantage?
December 27, 2008, 07:54:37 pm
madrogers
December 27, 2008, 07:54:37 pm »
heard some where on the forum that the lighter flywheel will rev up faster, less wight to get turning. and the better fuel mileage with less weight to move down the road HA HA .
Mark.
General Information
