Author Topic: Ecode headlamps in mk3 jetta with Intercooler.  (Read 3762 times)
May 13, 2013, 05:34:03 pm
mzak88
  • 31
« on: May 13, 2013, 05:34:03 pm »
Anyone try this with factory side-mount Intercooler? Looks like top boost tube would be in the way.
97 IDI Jetta, O2A CTN,0.658 5th, 1.6 boost pin, TDI IC, 2.0 brakes, some tuning.
Reply #1May 13, 2013, 06:26:50 pm
Re: Ecode headlamps in mk3 jetta with Intercooler.
« Reply #1 on: May 13, 2013, 06:26:50 pm »
ahhhhh  back in 99 i did ecode on 97 jetta tdi...
the issue.... real e codes fit euro front crossmember.... usa dot are different... but you could build new mounts from sheet metal
Reply #2May 13, 2013, 07:19:33 pm
mzak88
  • 31
« Reply #2 on: May 13, 2013, 07:19:33 pm »
I've actually had my ecodes installed for quite a while now... The REAL issue is I have an Intercooler from 98 Jetta TDI, my car is 97 AAZ TD (Canadian) non-IC'ed mechanical diesel. I was toying with the idea of using this IC on my ride. Looks like top tube needs to go right where the drivers side Ecode protrudes. Or am I wrong?
Reply #3June 01, 2013, 06:36:07 pm
GEE-BEE
  • 1604
« Reply #3 on: June 01, 2013, 06:36:07 pm »
Have a thin custom interccoler made
customintercoolers.com
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4June 03, 2013, 06:20:24 pm
« Reply #4 on: June 03, 2013, 06:20:24 pm »
im sure it all fits.. european TDIs had Ecode lights, and still had intercoolers as well...
