Author Topic: So where does one find a center console?  (Read 10319 times)
February 19, 2011, 02:19:59 am
trav1856
  • 230
« on: February 19, 2011, 02:19:59 am »
I've looked all over for aftermarket interior parts and I've been coming up with nothing. For my Fairlane Dearborn and a few other places had complete replacement parts, I was hoping I could find something like that. A company that catered to us VW people.
1981 Rabbit Diesel
1981 Cabriolet
Reply #1February 19, 2011, 07:56:16 am
GEE-BEE
  • 1604
Re: So where does one find a center console?
« Reply #1 on: February 19, 2011, 07:56:16 am »
have a rabbit GTI console on ebay
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 19, 2011, 01:25:43 pm
macka
  • 957
« Reply #2 on: February 19, 2011, 01:25:43 pm »
Usually we hunt down stuff on ebay or in the scrap yard. If we can't find it, we get a vinyl paint match and paint over the piece we need in the colour we need.
Quote from: Vincent Walden
Reply #3February 19, 2011, 06:38:57 pm
trav1856
  • 230
« Reply #3 on: February 19, 2011, 06:38:57 pm »
Has anyone ever tried to fit a newer rabbit console (Mark V'ish) to an older Rabbit? Do the dimensions even compare?
1981 Rabbit Diesel
1981 Cabriolet
Reply #4February 19, 2011, 09:51:14 pm
Quantum TD
  • 1195
« Reply #4 on: February 19, 2011, 09:51:14 pm »
I'm sure SOMEONE has tried it. But I think they're not even close.
Reply #5February 19, 2011, 10:34:10 pm
mystery3
  • 774
« Reply #5 on: February 19, 2011, 10:34:10 pm »
GTIs in the junkyard, or alter a cabby one, they're readily available in the junkyard. I believe zender or some other period aftermarket company made them as well, you may find one in the vortex classifieds. like this: http://forums.vwvortex.com/showthread.php?4674997-FS-NOS-Kamei-center-console-!-golf-rabbit.&highlight=center+console
Reply #6February 21, 2011, 09:28:38 pm
madrogers
  • 165
« Reply #6 on: February 21, 2011, 09:28:38 pm »
I modified a 84 nissan pickup console to fit it worked out pretty good .
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #7February 22, 2011, 07:19:07 am
« Reply #7 on: February 22, 2011, 07:19:07 am »
yes, but the kreason piece is fairly close in dimensions to the VW console..
if you need a rabbit console, find a cabby and yank it..
Reply #8February 22, 2011, 07:56:30 am
VWCaddy
  • 85
    • VW Caddy Page
« Reply #8 on: February 22, 2011, 07:56:30 am »
Got mine from someone on one of the old VW mailing lists many years ago, not exactly sure what is was out of):
Still need to re-install the ashtray and lighter socket to hide the wiring and terminal block I added.
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Reply #9February 22, 2011, 08:00:20 am
« Reply #9 on: February 22, 2011, 08:00:20 am »
how you gonna re-install the ash tray when you cut away the mounts for it?
Reply #10February 22, 2011, 08:05:30 am
VWCaddy
  • 85
    • VW Caddy Page
« Reply #10 on: February 22, 2011, 08:05:30 am »
I plan to replace the back part with some threaded inserts to make it easier to remove if needed in the future.  The ash tray part will attach back to that and cover the gap.
Reply #11February 22, 2011, 08:28:22 am
GEE-BEE
  • 1604
« Reply #11 on: February 22, 2011, 08:28:22 am »
That's a hack job.....
just buy either a cabby or rabbit gti console and your done...
Giles Pump OHC
MK1 JETTA DASH
Reply #12February 22, 2011, 08:33:12 am
« Reply #12 on: February 22, 2011, 08:33:12 am »
i agree..
GTI/Cabby consoles are common, and bolt right in..
Reply #13February 22, 2011, 06:17:15 pm
mystery3
  • 774
« Reply #13 on: February 22, 2011, 06:17:15 pm »
The cabby ones don't fit quite right either at least in my 81 truck. I'll have to make a little bracket to bolt it up. It'll fit in nicely with my interior which is completely void of everything I don't find necessary like doorcards, headliners, carpets etc.
Reply #14February 23, 2011, 08:33:54 am
« Reply #14 on: February 23, 2011, 08:33:54 am »
the early 80s cabby console i had, fit in my 81 rabbit perfectly.. mounted up to all the stock brackets..
