Author Topic: Torque Wrenches?  (Read 3987 times)
May 24, 2011, 06:43:42 am
ffgb
  • 244
Torque Wrenches?
« on: May 24, 2011, 06:43:42 am »
I have used torque wrenches forever but a little concerned here.  Are torque wrenches accurate when turned upside down?  I am going to pull my pistons with the motor still in to check for piston ring breakage and was a little concerned with using my Husky torque wrench upside down to torque my ARP connecting rod bolts!  I rebuilt this motor with using the torque wrench right side up!
Reply #1May 24, 2011, 08:25:00 am
macka
  • 957
Re: Torque Wrenches?
« Reply #1 on: May 24, 2011, 08:25:00 am »
yup the work upside down too  ;D even in space with no gravity.
Quote from: Vincent Walden
Reply #2May 24, 2011, 09:46:04 am
« Reply #2 on: May 24, 2011, 09:46:04 am »
I'd be suspicious of a Husky one anyway...but the Snap On  guy put my  Harbor Freight special on his calibrator, and it works just as good as his , so who knows.
Reply #3May 24, 2011, 11:16:48 am
Quantum TD
  • 1195
« Reply #3 on: May 24, 2011, 11:16:48 am »
Some shops require calibration every 6 months. But I think 2 years is a good idea. I'm overdue to have mine calibrated (Sears clickers). It's amazing how accurate those harbor freight ones are at like $10-20.
Reply #4May 24, 2011, 11:37:55 pm
« Reply #4 on: May 24, 2011, 11:37:55 pm »
My HF is almost brand new, as it's predecessor launched  bits of the head off into the woods one day.
Mostly I use my SK because it feels so much sweeter.
Reply #5May 25, 2011, 03:26:48 am
Patrick
  • 1034
« Reply #5 on: May 25, 2011, 03:26:48 am »
Where I work they test them every year. Never had a problem with calibration on a 1/2 inch one of any brand, but the 3/4 inch ones are a different story..... Don't imagine anyone needs the big one for anything they're discussing on this board!:D
Reply #6May 26, 2011, 09:23:21 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #6 on: May 26, 2011, 09:23:21 am »
We calibrate ours every 3 months.   One thing to keep in mind with click types is to back it off to the bottom setting (but not below) so that you don't get a set on the spring.   That's our most common cause of failing calibration, next is dropping them.   They should also not be used to loosen hardware.
Calvin
91 VW Golf 1.6NA 5spd
