Author Topic: Brakes  (Read 2664 times)
April 13, 2011, 08:11:23 pm
BillyWillicker
  • 111
Brakes
« on: April 13, 2011, 08:11:23 pm »
Hi!  I have a 1990 Audi 90 quattro that I am putting a 1.6TD into and am also uprating the brakes on.
I have wilwood superlite II calipers in the front and wilwood dynalite billets in the rear and will be running a dual master/bias setup.  There is no power assist and I am wondering what size master cylinders to run for the front and rear.
I can use 1", 7/8", 3/4".  I have to measure the piston diameters on the calipers yet, I know that is a big thing to know but I am looking for suggestions.  Thanks guys.
Reply #1April 14, 2011, 10:18:33 am
VWCaddy
  • 85
    • VW Caddy Page
Re: Brakes
« Reply #1 on: April 14, 2011, 10:18:33 am »
Might want to contact Wilwood tech support and see what they recommend:
- http://wilwood.com/Index.aspx
I have some Wilwood 4 piston calipers on the front of my 4x4 (plus some single piston Celica calipers on the rear) and will be upgrading to the 1" bore m/c.  Currently running a smaller m/c and I do bottom out the pedal to just barely get the tires to lock up.  With the large m/c, will also be installing a dual diaphram booster to cut down the increased pedal pressure.
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
