General Information
Upgrades (non engine related )
Cruise Control
Topic: Cruise Control (Read 3706 times)
May 23, 2011, 07:57:06 am
jbm2k6
Cruise Control
May 23, 2011, 07:57:06 am »
Hi Everyone!
I've read over a few of the topics posted in the past on this subject, but I haven't come up with some clear answers to go forward with this project. I'd like to add cruise control to my 85 Jetta 1.6 NA, which has the original CE1 wiring setup. Is there any easy way to pull this off while using a stock turn signal stalk with the cruise button on it? I'd prefer to not have an aftermarket controller on my dash if possible.
Any information is greatly appreciated! Thanks!
May 23, 2011, 09:18:56 am
Re: Cruise Control
May 23, 2011, 09:18:56 am »
No reason why you couldn't get all the parts from a donor- control unit, speed pickup [behind speedo] , brake and clutch switches, pump vacuum canister and rod ,control switch, vacuum hoses and wiring. It be easiest if you have the donor besides you to install it all properly . Oh and a bentley to troubleshoot. The vacuum brake and clutch switches have to be adjusted properly
May 23, 2011, 09:20:09 am
Re: Cruise Control
May 23, 2011, 09:20:09 am »
and you get the parts from a gasser .The only difference is where the vacuum canister mounts [throttle/IP]
May 23, 2011, 10:11:58 am
jbm2k6
Re: Cruise Control
May 23, 2011, 10:11:58 am »
I didn't even think about that. I figured stock parts wouldn't be worth it at this point based on my assumption that they would be worn out, non-functional, etc. I haven't had much luck locating a car whose cruise control system around is still intact around here. Perhaps it is something I can piece together.
May 23, 2011, 11:03:46 am
Re: Cruise Control
May 23, 2011, 11:03:46 am »
You could post a WTB in the classifieds. That way you may even get a diesel setup. Most of the time the failures were the vacuum hoses wearing out and sometimes the control unit. There is a troubleshooting guide available, but if you can't find it i can send you the info to trouble shoot if and when you get it all installed
May 23, 2011, 03:28:32 pm
rallydiesel
Re: Cruise Control
May 23, 2011, 03:28:32 pm »
I have some of the parts but I have no idea what failed because it was already inop when I got the car. That's the hard part, paying good money for parts that may or may not work.
1991 Jetta TD - sold
2001 Golf TDI - Son's
May 23, 2011, 03:53:23 pm
jbm2k6
Re: Cruise Control
May 23, 2011, 03:53:23 pm »
My thoughts exactly. I guess that would be more parts to add to the list of parts I need for the car, ha ha. Thanks for the info!
General Information
Cruise Control
