Author Topic: Wiring to rear door/trim removal  (Read 3129 times)
March 04, 2011, 06:16:41 pm
Squidbait
  • 36
« on: March 04, 2011, 06:16:41 pm »
OK, so I'm still waiting for my Bentley's for my 1996 Golf TD to ship  >:( , so I'll ask you guys:
Anyone know how to get the door sill trim pieces off?  Do they just snap on/off, or are there some hidden screws somewhere?
The wiring to my rear passenger-side door speaker has a break in it somewhere, so even if I have to re-run the leads, I'd like to know how to get the trim off, since I'm assuming that's where the harness runs - from the dash, along the door sill, up the B-pillar and into the door?
Eagles may soar, but weasels don't get sucked into jet engines.
Reply #1March 05, 2011, 10:11:55 pm
  • 1739
Re: Wiring to rear door/trim removal
« Reply #1 on: March 05, 2011, 10:11:55 pm »
open the door and you'll see the bellows for the wiring. carefully peel the rubber bellows off the connector. you will must likely see broken wires there
Reply #2March 05, 2011, 10:17:17 pm
  • 1739
« Reply #2 on: March 05, 2011, 10:17:17 pm »
to take the door trim off- remove the lock knob at the top, remove the grab handle outside half by carefully getting a flat screwdriver between the two plastic halfs. there are 2 phillips machine screws -remove both. push the lock handle bezel by sliding it forward. there may be a small phillps screw behind it. then remove the 6 screws holding the panel, 2 at the front edge, 2 on the bottom[you will have to feel or bend way over to see them and 2 more at the rear edge. They might be 3 or something mm
Reply #3March 06, 2011, 11:44:52 am
Squidbait
  • 36
« Reply #3 on: March 06, 2011, 11:44:52 am »
D'oh!  I never even considered the obvious wear point!  I was too busy worrying about a bug-hunt.  :-[  Thanks!
That's exactly where the break was, both wires.  I spliced in a little spacer stretch, but when it warms I'm going to re-run the wires.
Is that a strain-relief in the pillar or a full-on connector?
Reply #4March 06, 2011, 11:58:35 am
  • 1739
« Reply #4 on: March 06, 2011, 11:58:35 am »
It's a full connector that can easily be detached by grabbing it at the b-pillar end and twisting it and turning counter-clockwise. When re-attaching, be careful to line it up properly. Detaching can make repairs easier, as there's less strain.
