Something about "getting there is half the fun" that I find wildly appealing. Although, I agree with you, I am usually frugal, but lets face facts, I am a Marine, and as such, a little on the insane side.
thanks guys,
Kevin
you must really believe I'm daft? I am going to see just how rough cold starts are on the 1.5 bottom end
and use it on that with standard 1.5 N/A pump and injectors basically, I'm curious to know if an aaz head will really work, or be practical on a 1.5 bottom end. I'm going in not expecting it to work and if it does..... well, then I have a good breathon N/A 1.5 with super low static compression, and probably ***ty milage, depending on how it's tuned. Any advice? Curiosity killed the cat...... and my wallet
daft?
im a stoner with a limited vocabulary, un common words dont get along with me.
and good luck on the 1.5/9 n/a its probably gonna have around 15:1 compression or so, cause the 1.9 pre cup is almost 20 cc's, and the 1.5 pre cup is around 11 cc's. thats almost a 200% increase. might work, probably wont. it would be cool if it did tho. i just think i could spend 300 dollars more wisely then trying to fix a junk head is all. 1.9 heads are not rare. theres just not much VW diesel stuff in cali, or oregon, or washington really, but if we made a trip to canada one of these days, we would be set...
I'd go at the drop of a hat, but there's the whole Military thing
I don't have many choices on heads here, true! I have a better one on it's way, and I am curious to try this, that's the bottom line.
Ok, now for some pictures.
would fuel cooling be beneficial? I am going to install a toggled pick up pump, and since it is fuel cooled, I wonder "SoCal is mostly warm all year" if it would be beneficial to cool the fuel? These were originally used for JP8 cooling, and they still have some inside
I need everything cept the cam, cambolt and washer, valve cover and gasket, cam, and valves. I need the sensor, gaskets, guides, valve seats, freeze plugs, everything. I also need to figure out what the hole in the cam cover is for and what the heck I'm spoze to do with it???
You, my friend, have a touch of insanity that has made this thread a lot of fun to read.
I can't wait to see where you go with this.
Cheers,
Ryan
I do understand that it will not be a 1000 H/P engine or anything but Brake H/P wise it will be in a league all it's own.
I mean, what, the Mk1's weigh about like 1100lbs soaking wet with a full tank and a fat chick in the back?
