Author Topic: 1.6 cy TD bottom end 1.9 aaz head project  (Read 129813 times)
Reply #405April 02, 2010, 01:14:37 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: 1.6 cy TD bottom end 1.9 aaz head project
« Reply #405 on: April 02, 2010, 01:14:37 am »
I have seen it, now what is the suggestion? ???  update time, I have ordered a powdercoat system "vwdiesel members get a discount ;)"  I will be powdercoating everything, as well as checking on the ststus of the head I had sent out to be repaired "out of sheer curiosity"  I will also send out the crank to castillo's to be lightened, and start ordering all of the particulars.  Once the 80' rabbit is together and sold, then I will start getting all of the go fast parts.  I am also going to be sending out my injectors and pumps to giles this week sometime, by the by, has anyon eheard from him in a while?  I tried e-mailing but no cigar??? :'(
Reply #406April 02, 2010, 04:44:20 am
ein bora
  • 377
« Reply #406 on: April 02, 2010, 04:44:20 am »
If you don't mind me asking - how much is a system??
If you can't take advice - then you can't be helped!
Reply #407April 02, 2010, 09:33:27 am
« Reply #407 on: April 02, 2010, 09:33:27 am »
Best bet is to call him - he usually does respond to email, eventually.  He's much more of a "let's talk" type of person though from what I gather.  Guess he's too busy in his shop working on things to be sitting in front of the computer!
Reply #408April 02, 2010, 09:51:22 am
NintendoKD
  • 931
    • myspace page
« Reply #408 on: April 02, 2010, 09:51:22 am »
makes perfect sense, good man 8)
Reply #409April 02, 2010, 06:35:50 pm
sdwarf36
  • 159
« Reply #409 on: April 02, 2010, 06:35:50 pm »
I talked to him Tues.? this week. He was just starting on my pump that i sent about 2 weeks earlier. So you can judge off that.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #410April 05, 2010, 12:57:40 am
  • 3468
    • McScrubbins Body Wash
« Reply #410 on: April 05, 2010, 12:57:40 am »
i drilled the "steam holes" in my 1.6/1.9
it really speeds up the time it takes to get coolant in the whole thing and purged of all bubbles.
Reply #411April 07, 2010, 08:10:53 pm
NintendoKD
  • 931
    • myspace page
« Reply #411 on: April 07, 2010, 08:10:53 pm »
Was away for a few days doing some pre-deployment training for afghan, and thought that I would share.
Reply #412May 30, 2010, 10:56:57 am
NintendoKD
  • 931
    • myspace page
« Reply #412 on: May 30, 2010, 10:56:57 am »
Ok, been a while since I posted here, but I have some time to work on things a bit, but come to find out my Machinist has a brain tumor and will no longer be able to provide his services, as well as not doing any of the Machine work that I sent him to do anyways.  I now have a tranny for the project, and will now need the aid of a driveline shop to build the custom driveline for the spyder.  In the meantime I am finishing the build on the 1.5 and now need to send the head off to be rebuilt, and might as well have it sent to the guy in ohio as well as the aaz heads and a certain gti head that I have to get ported out and rebuilt.
Reply #413May 30, 2010, 11:27:15 am
« Reply #413 on: May 30, 2010, 11:27:15 am »
i thought that head was no good? keep your eyes open for another solid lifter head..
Reply #414May 30, 2010, 01:48:47 pm
NintendoKD
  • 931
    • myspace page
« Reply #414 on: May 30, 2010, 01:48:47 pm »
I am swapping the valves etc. to an 86 gti head that is a hydro head and am having that head fixed up real nice like ;D 86 gti hydro head 84 gti valves cam etc. ooh yeah
