Author Topic: 1.6 cy TD bottom end 1.9 aaz head project  (Read 130509 times)
Reply #150December 10, 2009, 05:44:36 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: 1.5 rot assy. 1.6 TD bottom end 1.9 head project
« Reply #150 on: December 10, 2009, 05:44:36 pm »
cool :D  what about meth injection?
Reply #151December 11, 2009, 10:02:30 am
« Reply #151 on: December 11, 2009, 10:02:30 am »
methanol just keeps your egt's down. its more a chemical intercooler rather than a power adder.
Reply #152December 12, 2009, 07:57:33 am
« Reply #152 on: December 12, 2009, 07:57:33 am »
...although if you can knock your EGT's down then you can run more fuel... :D
Reply #153December 12, 2009, 08:00:42 am
« Reply #153 on: December 12, 2009, 08:00:42 am »
true, so i guess you could get more power from using methanol, but just not directly from the methanol.
Reply #154December 12, 2009, 10:14:25 am
NintendoKD
  • 931
    • myspace page
« Reply #154 on: December 12, 2009, 10:14:25 am »
so....... run the twin turbo setup with meth injection.  hmmmm... but that cuts out the ability to daily drive.  I still want that.  Gotta teach these yunguns a thing or too "them and their stupid mustang gt's"
Reply #155December 12, 2009, 10:39:19 am
« Reply #155 on: December 12, 2009, 10:39:19 am »
if you run compounds, you WILL bend rods, blow head gaskets, warp/crack heads, etc, etc. if you want THAT much boost, go with one big single with a shot of nos to spool it. most people on here are staying away from compound turbos for that reason. vw's dont take huge boost like a 12v cummins. if we could come up with a cast iron head, or some sort of head girdle, we could build some serious horsepower. but the heads on our vw's flex with too much boost. the head actually bends..
Reply #156December 12, 2009, 01:13:39 pm
NintendoKD
  • 931
    • myspace page
« Reply #156 on: December 12, 2009, 01:13:39 pm »
 :o wicked  I kinda want to see that........ but I also kinda don't :'( okay so what can I do "other than nos to spool the big bad boy up?
44 psi thats ruff I think that 35-40 will be far more than enough for me.  I was thinkin mid engine mounting it too good? bad? put a firewall behind the drivers seat, use the moonroof as a vent for the intercooler/cold air induction and make a custom exhaust to come out of the roof flush with the roof 8)
Reply #157December 13, 2009, 08:32:53 am
« Reply #157 on: December 13, 2009, 08:32:53 am »
why not just bolt it in the front of your rabbit? it botls in, its gonna be fun as hell. its like driving a street legal turbo charged diesel go cart. and if you do put the engine in the middle, i would put the i/c and radiator behind the grille like they were supposed to be. just use an electric fan, it will work great, and run the exhaust right out the stock spot. but a car like this has already been built, somebody over in europe has a 78 rabbit with a Mtdi and an audi transmission backwards. its basically just like a bug drivetrain setup. i just think that pulling air through your sun roof would be kinda dumb. sun roofs dont breathe very well as it is, so why not put your stuff to be cooled somewhere that they get tons of air? ie: stock location.. i was just thinking of the toyota previa van, they had the engine on its side about mid way back, and a jack shaft off the front running the accessories.
Reply #158December 13, 2009, 12:09:39 pm
NintendoKD
  • 931
    • myspace page
« Reply #158 on: December 13, 2009, 12:09:39 pm »
custom roof scoop, already made it.... well, the mold at least  I'll post up some pics later.  My wife still has connections in Okinawa, Japan so I might just be able to get a hold of one of those.
Reply #159December 13, 2009, 03:02:41 pm
maxfax
  • 2126
« Reply #159 on: December 13, 2009, 03:02:41 pm »
The roof scoop woudl just be aerodynamic drag..  Since the front end of these cars is already an aero dynamic drag why not take advantage of that?    Putting the rad and IC out fround woudl help keep some heat ou of the passenger compartment..  Remeber that not only do you need to get the air into this stuff, it's gotta come back out just as fast, well probably faster since it's hot and expanded...
This is all getting me thinking about a TD Fiero again..  ;D
Reply #160December 13, 2009, 09:47:08 pm
NintendoKD
  • 931
    • myspace page
« Reply #160 on: December 13, 2009, 09:47:08 pm »
I have thought about that too, and came up with some interesting ideas, still on the edge about this one ???
Reply #161December 14, 2009, 09:10:19 am
« Reply #161 on: December 14, 2009, 09:10:19 am »
the front of the car is set up to house everything already.. i would go for that. atleast for a little while.
Reply #162December 14, 2009, 11:34:51 am
NintendoKD
  • 931
    • myspace page
« Reply #162 on: December 14, 2009, 11:34:51 am »
for now I think that I will just use a front standard type setup...... for now ;D
Reply #163December 16, 2009, 06:34:41 pm
NintendoKD
  • 931
    • myspace page
« Reply #163 on: December 16, 2009, 06:34:41 pm »
Ok, I got my pump in today, I'm going to look into the DIY section for the rebuild info, however, is there a place that I should go to or stray away from for the rebuild kits?  also where can I get one of these land rover pins for the pump or is it even worth it?
thanks guys,
Kevin
Reply #164December 16, 2009, 06:58:03 pm
« Reply #164 on: December 16, 2009, 06:58:03 pm »
NOBODY ON HERE really has a build up with a nitrous setup if i remember right.
Dr Diesel had a mk2 TD with nitrous.
On an unrelated note I heard rumors of a guy that built his own cast iron head. 80 psi rings a bell ;)
