1.6 cy TD bottom end 1.9 aaz head project
by
NintendoKD
on 18 Nov, 2009 16:25
Ok, well if you read the top then you know what I'm up to I AM GOING TO DO IT! seriously the audi 500o intake looks promising but I am open to better designs and Ideas I have the 1.5 rot assy and the 1.6TD bottom end still in need of the turbo, ex mani. downpipe? arp studs, metal head gasket, piping, intercooler, and odds and ends. I am told that this is always talked about but never done well here goes I need cash and I have stuff up for sale/trade too so If you can help that would be just spectacular.
#1
by
MJF
on 19 Nov, 2009 00:10
TDI head? What pistons and rods are you going to use?
#2
by
NintendoKD
on 19 Nov, 2009 08:45
The stock 1.5ers. Are they too weak? I was under the impression that the stock internals are very strong just the 1.5 block is weak. This information is good to know off-the-bat so I don't make any fatal errors during the build phase.
thanks,
Kevin
#3
by
on 19 Nov, 2009 11:05
First mistake, you can't use a TDI head with IDI pistons.
by
NintendoKD
on 19 Nov, 2009 13:56
"sexy party" Good to know, where do I get some stronger pistons that will fit the job at hand? "sexy party".........................................
... "SEXY PARTY!"
#5
by
MJF
on 19 Nov, 2009 14:16
Custom.
Nothing matches between TDI and 1,5. Cylinder bore, rod journals, piston height, piston pin, rod length, all are different in stock parts.
E: 1,2L 3 cyl Lupo engine has 76,5mm bore and 24mm piston pin. Maybe you could use those.
#6
by
rallydiesel
on 19 Nov, 2009 14:58
Were you intending on a TDI or IDI? Because using the 1.9 IDI head would be pretty straight-forward.
#7
by
NintendoKD
on 19 Nov, 2009 17:53
going turbo all the way baby, I was told that the 1.5 rotating assy would fit right into the 1.6 TD block this is not true? I was misinformed? also veeery good to know so the question still remains where do I get said internals for the bottom end??? THe idea here folks is to build a high "for a diesel" revving boost hungry heavy breather turbo beast engine "like legos" with strength and some "I mean look at what we are trying to achieve here" reliability.
Thanks,
Kevin
#8
by
MJF
on 19 Nov, 2009 22:38
TDI or IDI head? Two very different things. Other easy, other not.
#9
by
NintendoKD
on 20 Nov, 2009 01:59
AAZ TDI head I said "boost hungry" right?
#10
by
Turbinepowered
on 20 Nov, 2009 04:51
AAZ is not a TDI. AAZ is IDI. You're in the wrong section here, bud.
You want the next forum down on the main page. A 1.5 rotating assembly with a 1.9 head is gonna be some major cold starting issues with super-low compression.
#11
by
NintendoKD
on 20 Nov, 2009 09:28
cold start? bring it on!
and once again, good to know, I would hate to be looking for someting that does not exist.
thanks,
Kevin
#12
by
NintendoKD
on 20 Nov, 2009 09:38
#13
by
rallydiesel
on 20 Nov, 2009 10:38
You've got to do your homework before you start into a potentially impossible project. What people here are trying to explain to you is that the AAZ is an
IDI engine. You can use the oem 1.5 pistons with this head. If you were to use a true TDI head, you would need to use TDI pistons. Meaning you would have to find/make some since there is no plug and play TDI piston to use in the 1.6 block.
#14
by
drrtybyl
on 20 Nov, 2009 10:51
There's a pretty good discussion of the 1.5 assembly/1.6 block/1.9 head idea in Saurkraut's thread (lots of measurements and considerations):
http://www.vwdiesel.net/forum/index.php?topic=11786.60You may have to circumcise your 1.6 block to make it work.
Also, you'll need a 1.6 block that doesn't require boring because oversized 1.5 pistons are very difficult to find. Someone was selling them on here at one point, but they were pricey.
