View full version: Parts for Sale/Wanted
  1. FS: [Sold] M-TDI pump
  2. FS: syncro 15" Le Castellet rims *PICS ADDED*
  3. Alternator w/AC and PS Bracket for AAZ engine
  4. wtb power steering pump
  5. Craigslist, NH: MkI Rabbit TD Basket Case ONLY $995!!!
  6. Looking for a T3 .48 A/R Turbine housing external wastegate
  7. WTB-rear springs and spring seats for A2
  8. Craig's List NH: 1985 Volkswagen Jetta Turbo Diesel! - $1200
  9. wtb rack and pinion linkage thingy
  10. AAZ part out - round 2
  11. WANTED - 1.6 TD boost PIN
  12. f/s: mk2 uk spec gtd top mount intercooler
  13. WTB Alternator clutch
  14. FS: 1998 Jetta TDI parts
  15. golf mk2 seat rail plastic holds
  16. WTB 6 cyl Mercedes OM 606 diesel engine
  17. two 1.9 td engines for sale
  18. A2 Jetta doors with pwr locks and windows
  19. FS: MK2 CE1 cluster w/ tach, BV block off plate & other.
  20. WTB 93 Jetta TD center muffler
  21. WTB: Rabbit diesel tranny ASAP
  22. Wanted T3 Turbine Shaft
  23. Need a source
  24. WTB: 1Z EGR Cooler Tubes......
  25. WANTED: T3 turbo and manifold
  26. parting out rust free 88 Jetta GL gasser in Ohio, near cincy
  27. WTT: My 2 plug cluster for your 1 plug cluster..
  28. FS: Intercooler and Pipes
  29. SOLD: (Edmonton AB) 1986 Turbo Diesel Jetta parts car
  30. FS: 1 Set Only - 1.9 AAZ Nüral/ Goetze Pistons .5mm OS $475
  31. Wanted. 1.9 aaz td engine uk
  32. F/S: 1998 Jetta TDI
  33. WTB-TD Head
  34. WTB Water Seperator
  35. Garage clean out - misc parts - Brackets, oil pan, intake...
  36. FS: K&N filter 33-2001 for VW diesel and some gassers to
  37. WTB MK1 Fuel filter mount
  38. wtb:vw 1.9 aaz injector pump timing sprocket
  39. UK: 02a box, VR6 clutch, AHU block, Suspension, 11mm pump
  40. MK3 jetta TDI 1999 intercooler + 02A tranny
  41. WTB: 1.6 NA Head! NEED Bad!
  42. 1.9TD rings and new/used 1.9TD pistons..?
  43. FS: Freshly Rebuilt T-3 Turbo 1.6 Turbo Diesel
  44. FS: InterCOOLER & PIPES
  45. LF: Rabbit or Caddy around southern Indiana
  46. WTB: 1.9 AAZ Exhuast and Intake manifolds
  47. wtb 8v gli downpipe
  48. LF: Early TDI Engine For Conversion
  49. Fs 80% tran kit
  50. body panels, front fenders, for a 1982 rabbit LS, roof rack!
