- Craigslist find Nice Vanagon in indiana
- vane and diaphragm vac pumps, vw and audi oil filter housing, N/A I.P. w/lines.
- FS Feeler: Clutchnet 210mm clutch setup
- Garage cleaning, 1.6, 1.9 AAZ, 1.9 1z/ahu parts + car parts mk2,3,4,b3,b4
- for sale 92 cabriolet 160k North Stonington CT $995
- feeler for MK3 jetta AHU for swap or??? bump for UPDATE !
- WTB: AAZ Rear Engine Mount Bracket
- Mk2 Drivers side headlight assembly WANTED
- 1.6na lighty used pistons and other misc parts
- F.S. 5th gear set
- F.S. 8V GTI dual outlet manifold+downpipe
- Wtb 1.6 TD intake manifold
- 1991 Jetta gl with an aaz (SOLD! to Ben)
- F.S. Godspeed 8V T3 turbo manifold, new in box
- lf mk3 tdi engine harness and DBW (pedal)
- FS: 10mm Peugeot Turbo injection pump
- FS: Diesel instrument cluster with tach
- F/S 98 Jetta engine $700
- FS:: MK2 bits and 1.6TD odds
- WTB Jetta TD
- SOLD ...Camshaft 1.6 for sale
- WTB: Bosch pop tester parts needed (fuel bowls, gauge, and injector line)
- wanted: r/s engine mount assb. for mk 1
- FS: 020 transmission
- Semi agressive boost pin
- Wanted: 1.6 Diesel Engine
- 78 ext caddy project.. ne ohio
- giles 1.6td pump fs
- New set of 1.6 NA Diesel Pistons over at the Vortex
- WTB 068130365A cruise control connecting link.
- WTB: AAZ Turbo/Manfold/Down pipe/Oil Lines
- FS BRM intake manifold
- Where to obtain 85 TD radiator fan ceramic resistor?
- WTB: PD150 intake manifold
- FT: Eco Diesel Turbo Hose for non-Eco Turbo Diesel Turbo Hose
- WTB K03 Turbo For B4 1Z TDI
- NEEDED: common ALH upgrade parts ex:egr delete plate
- WTB: AAZ injector pump 2-stage injector cam plate and 2 stage injectors
- Pop Tester Wanted!
- REBUILT Turbo Pump, Utah
- 1.6TD parts for sale
- FS: 1.9aaz complete bottom end
- Still looking for a rod for my AAZ!
- WTB Small bumper front fender barcket
- wtb mk1 cold start cable
- FS/FT: Full set of 4x100 18" rims.
- Needed; Uprated front brake pads for a std mk3 td
- AAZ very short blocks available.
- WTB: AAZ Valve Cover Hardware
- con rod for my AAZ
