View full version: Parts for Sale/Wanted
  1. wtb this ip part...
  2. NTB: 1.6TD MK2 rotary vacuum pump
  3. f/s: on ebay mk1 gauge consoles, Rabbit/Cabriolet tail lamp
  4. Mk2 AAZ Downpipe Needed
  5. FS: Complete 020 Flywheel and clutch kit. New.
  6. Wtb passat tdi harness
  7. wtb. vanagon diesel thermostat housing cooling flange. fair price.
  8. WTB: to spec 1.6td injector set, or have somebody rebuild mine?
  9. WTB ::::: AAZ IP Gear
  10. FS: injection pumps for cores with various issues(1 na, 1 turbo, 1 unknown)
  11. new sachs 8v clutch kit 210mm
  12. Ecodiesel Air box
  13. 1.6 parts
  14. FS- HD rear springs and shocks for Mk2 -$100
  15. WTB: D24T injection lines
  16. wtb: diesel 5 speed 020 (PA or close)
  17. F.S. Intermediate Shaft
  18. fs: aaz parts + vnt17
  19. stuff for sale
  20. Vacuum pump and timing covers
  21. WTB 1.6 L vane vacuum pump and vacuum check valve
  22. AAZ Summer Garage Cleaning
  23. WTB: 1.6TD Garrett turbo
  24. Diesel Overhaul kit $239 shipped
  25. WTB: b4 passat tdi turbo manifold for wastegate turbo.
  26. Wanted: AC compressor with bracket for 1.6TD jetta
  27. 82 rabbit diesel 4 door PNW $3000 SOLD!!!
  28. Letting go of a good friend :1991 Ecodiesel
  29. fs: assorted mk1 and mk2 GTI parts in Southern California
  30. vw diesel rabbit truck cabriolet custom turbo - $5000 (scotts valley) California
  31. Hyd cable clutch conversion, genuine vw parts NEW
  32. Passat TDI Quattro Wagon in Cambridge Ontario
  33. FS: stock turbo downpipe from mk2
  34. I need 6 020 pressure plate to crank bolts
  35. MOVED: Spare tire fuel tank
  36. WTB small bumper turn signal
  37. FS ..14" Alloy Wheels
  38. FS..Crank Pulleys for A/C
  39. wtb::: rhd mk1 steering rack
  40. AAZ caddy project! Needs assembly and paint plus a bit of welding.
  41. mk1 parts and diesel tools for sale UPDATED!
  42. WTB AAZ K03 3 bolt exhuast manifold
  43. FS: 1995 Jetta AAZ TD
  44. WTB: 2 pin flywheel 210mm
  45. wtb 1.5 fuel filter housing
  46. WTB: 1.6 TD non AC crank pulley, and WP pulley
  47. WTB: AAZ turbo intake hose
  48. FS 1997 passat TDI part out
  49. WTB: Both filter to pump lines for td
  50. FS Parting a 97 and 99 Jetta TDI
