For Sale/Looking For
» Parts for Sale/Wanted
View full version:
Buyer/Seller Feedback
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
FS MK2 CE1 Cluster with Tach
FS: mk2 ce1 cluster w/tach
where's a good place to buy injector inserts?
FS KS Pistons 1.6D +1.00 OS
WTB: 1.6 IP mount brace
FS: AAZ single stage injectors SOLD
WTB: AAZ IP lines and delivery valves
WTB: Tail Light Assembly 4-Door MK1 Rabbit
IDI VW Mk2 Mk3 Golf 1.9 AAZ TD TDI Intake Manifold Pipe
WTB 6BT cummins pump bracket
F.S. OEM Golf VI Mud flaps/Splash Guards
AHU parts wanted
WTB: K24 or T3 turbo, trapezoidal flange
WANTED INTERMEDIATE SHAFT FOR A 1Z ENGINE
F.S. Lower Outer Ball Joints
F.S. Tie Rod Ends
FS: single .25 over main bearings
F.S. Fuel and Water Filter
F.S. Universal Cruise Control System
WTB: oil dipstick and tube
FS NOS 1.6TD pump
WTB: 1.6D Cast Thermostat Housing Flange
Aftermarket Sunroof
F.S. OEM Golf III Tail Lights
F.S. Compass/Auto-dim mirror
F.S. R8 Oil Cap
FS / WTT Tiptronic Transmission Valve Body
1981 vw 1.6 idi part out.
AAZ injector lines
1Y Intake Manifold
FS: MK2 rear brakes
1.6td oil squirters
Wtb: 2 piece CCV breather tube
MK2 IDI parts
Audi 5cyl Diesel Oil Filters
FS: 1.6TD Nozzles Bosch New
FS: 2005 passat tdi 1.9l part out
1.6d parts
F.S. Bosch Oil Filters
CORES WANTED
For Sale: vw vanagon 1z/ahu tdi diesel conversion kit
WTB 11MM Bosch mTDI pump from LR 300TDI Pump
VW Quantum 5-cylinder 2.2 ...... need Flywheel
FS: ALH Aluminum Thermostat Housing
random Parts for sale AAZ AHU ALH
WANTED upgraded AHU rod, piston, and rod/main bolts
WTB Need timing belt cover 1.6 N.A. early 80's
WTB Turbo injection pump working
WTD AAZ or K14 Turbo cast iron housing
