Author Topic: AAZ caddy project! Needs assembly and paint plus a bit of welding.  (Read 3660 times)
June 30, 2013, 01:06:02 pm
Jagerauto
  • 144
Call or text 757-541-7377
I just don't have time for this anymore.
Truck is an 81 LX, I have all the trim pieces and chrome. Doors are off a 4dr Jetta with nice seals and solid 1/4 glass.  Has a clean title. I just recently started stripping the engine bay and it has started rusting, JUST surface rust! It has two rust holes in the inner fender, some small holes in the driver side floor pan, and a bit of rust in the bottom bed corner.
Tuck is sitting on front race land coil overs, raised early mounts, new control arms with poly, ball joint extenders.
Extra parts with truck:
Headliner board
Rear board
Mk1 Jetta dash and knee bar
Tailgate
Egg crate grill
More I'm sure
Motor! Everything listed is included
AAZ 1.9td 160k miles
Not assembled
Bottom end has been stripped of all the paint/rust.
Head was rebuilt, NEVER mounted! Rebuilt by Frank Irving! Spent $1000! Stage two cam/lifter set!
Arp head studs
New gaskets
T3 turbo
Exhaust/intake mani
AAZ injection pump
Valve cover
All the parts needed!
Bottom end was taken apart and lines with gear oil and torqued to spec before storage.
It has new seals
02J 5speed conversion with mk1 mounts!
Pulled out of a mk4 TDI
Have clutch and flywheel
Have shift box and cables
Needs to be stripped a little more, I started sand blasting and didn't finish
100mm hubs
New parts
Mk1 manual steering rack and tie rods/boots
Chrome door handles
Chrome flag mirrors
Smoked turn signals(westy)
Optima battery holder stainless steel
Optima red top
Front brake pads and rotors
Rear air shocks
Wheels:
On truck: 14" 5x112 Mercedes wheels Chrome with new 155/55/14 tires
Extra 15" 5x112 steelies with new 165/40/15 tires.
Adaptec 4x100 to 5x112 18mm adapters
Looking to sell all this as a whole hopefully. There is a ton of money here!!!!!
Conservative pricing:
Truck with all original parts to go with it but not front suspension $900
02J swap $800
Motor and all it's parts $3000
Mercedes wheels with tires $700
Steel wheels with tires $400
Chrome flag mirrors and handles $200
Other new parts $200
Other spare parts $400.
Looking for offers on everything a a whole or individually, if your looking at something individually don't expect to pay any less than the above pricing.
As the truck sits now...
The motor/ looks bad but it's the stripper I used that made it turn white like that. Just needs a light wire wheeling and some paint!
Trans
