Author Topic: WTB: AAZ Rear Engine Mount Bracket  (Read 5313 times)
October 02, 2012, 07:04:26 am
« on: October 02, 2012, 07:04:26 am »
A long time ago in a land far far away someone swapped a 1.6 into my Mk III.  After several years of dealing with engine mount related issues, I finally figured out they kept the rear engine mount bracket off the 1.6 and just drilled a hole in it to "fit".  Unfortunately it's waaaay too short so the engine isn't sitting right and it is going to rip apart the front mount in no short order.
Looking for the rear mount bracket for an AAZ, preferably one in Canada.  Would like to see a pic so I know it's the right part!
Thanks!
Reply #1October 02, 2012, 10:44:33 am
Re: WTB: AAZ Rear Engine Mount Bracket
« Reply #1 on: October 02, 2012, 10:44:33 am »
hey bud, the ABA (2.0L mk3 8v engine) should have used the same mount..
and it will be much easier to source..
Reply #2October 02, 2012, 11:27:15 am
rodpaslow
  • 670
« Reply #2 on: October 02, 2012, 11:27:15 am »
I think they all, all sizes of engines use the same one. I have one from a 1.8 can(I went to a vnt so I had to replace it). I assume a 1.9D block will be very similarly sized to this 1.8 gasser it came from.  You can have it for only shipping cost if you want it.  MK III golf it came from.
Reply #3October 02, 2012, 12:07:32 pm
« Reply #3 on: October 02, 2012, 12:07:32 pm »
yes, that should fit as well.. forgot the mk3 came with a 1.8 as well..
it HAS TO be a mk3 piece tho..
Reply #4October 02, 2012, 02:14:04 pm
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« Reply #4 on: October 02, 2012, 02:14:04 pm »
I have a couple mk3 engine mount brackets. I even have one already bead blasted! $20 plus shipping!
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #5October 02, 2012, 02:19:42 pm
slowcaddydan
  • 20
« Reply #5 on: October 02, 2012, 02:19:42 pm »
I have an AAZ rear mount i'm not using but i'm in California so it's definitely not worth it to you. I can, however, post a pic if you want for comparison -maybe even pull a part number from under all that grease :)
Reply #6October 02, 2012, 02:32:40 pm
« Reply #6 on: October 02, 2012, 02:32:40 pm »
I have some I made for VNT usage. I will bump the thread.
Reply #7October 02, 2012, 08:22:03 pm
« Reply #7 on: October 02, 2012, 08:22:03 pm »
Pretty sure I have an AAZ one on the back of my AAZ engine that I don't need. However like it was said, ABA or 1.8 mk3 engine likely is identical.
Reply #8October 03, 2012, 09:52:28 pm
GTiTDi
  • 153
« Reply #8 on: October 03, 2012, 09:52:28 pm »
If you still need the mount how does 10 bucks plus shipping sound? ;D
Reply #9October 04, 2012, 05:06:49 pm
« Reply #9 on: October 04, 2012, 05:06:49 pm »
Hey everyone, rodpaslow has one coming my way.  Thanks!!  Next task will be the "fun" of swapping that out.  Hopefully before the weather changes...
Reply #10October 04, 2012, 05:17:41 pm
« Reply #10 on: October 04, 2012, 05:17:41 pm »
its really not that hard.. i can do it from above.
just un bolt the mount from the isolator
lift the passenger side of the engine with a jack, about an inch
un bolt the existing mount, replace with new one..
be sure you have the right bolt to secure the new mount to the existing isolator..
Reply #11October 05, 2012, 07:08:02 am
« Reply #11 on: October 05, 2012, 07:08:02 am »
It appears there is a stud there now... Looking at the VAGCAT diagrams it appears to be the same as the "double stud with hexagon drive" so hopefully I'll be ok.  That would SUCK if not.
Good to know.  Above would be much "friendlier" in my work area.
Reply #12October 05, 2012, 07:22:17 am
GTiTDi
  • 153
« Reply #12 on: October 05, 2012, 07:22:17 am »
It is basically a bolt with a stud sticking out of the head. On Gassers it holds the bracket to secure the O2 sensor connectors.
