Author Topic: Mk2 Drivers side headlight assembly WANTED  (Read 7588 times)
September 30, 2012, 06:49:05 pm
fdnyguy
  • 499
« on: September 30, 2012, 06:49:05 pm »
Need a Euro drivers side headlight assembly. Seems mine has a hole in it and filled with water during a nasty storm Friday, ruining the headlight.
P.S. Car runs great, I'm keeping it. :)
Thank you in advance.
Stay safe, stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #1September 30, 2012, 08:31:13 pm
Re: Mk2 Drivers side headlight assembly WANTED
« Reply #1 on: September 30, 2012, 08:31:13 pm »
That is what I call "headlamp fluid" it is liquid electricity LOL
Drill a hole in the bottom really small and it will get you by until you can find one. I know they have them on fleabay if you don't find one here.
« Last Edit: October 01, 2012, 06:58:36 am by theman53 »
Reply #2October 01, 2012, 06:56:17 am
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« Reply #2 on: October 01, 2012, 06:56:17 am »
They are not side specific! R will fit L and vice-versa!
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #3October 01, 2012, 07:00:19 am
« Reply #3 on: October 01, 2012, 07:00:19 am »
I am pretty sure they are not. I am not sure what Euro is but I have had both the aero and rounds and both were side specific. Unless you were thinking he just needed the bulb or there are ones that are interchangable that I haven't had.
« Last Edit: October 01, 2012, 09:23:57 am by theman53 »
Reply #4October 01, 2012, 07:07:55 am
fdnyguy
  • 499
« Reply #4 on: October 01, 2012, 07:07:55 am »
Ok, Ill drill a small hole and silicone the little hole and try it. Never realized they were interchangable. This site is tops for the N/A.
As usual, thanks again.
Reply #5October 01, 2012, 09:30:07 am
GTiTDi
  • 153
« Reply #5 on: October 01, 2012, 09:30:07 am »
The round lens headlights ARE symetrical, I just got a new set and there was no difference! VW is just that clever. The aero headlights are asymetrical though...
I picked up a set of Autopal mk2 e-codes for short money off Flea-bay
http://compare.ebay.com/like/330510020853?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
Reply #6October 01, 2012, 12:05:49 pm
fdnyguy
  • 499
« Reply #6 on: October 01, 2012, 12:05:49 pm »
Don't need the bulb. Need the housing. Water was in housing and killed bulb inside.
Reply #7October 01, 2012, 12:19:58 pm
« Reply #7 on: October 01, 2012, 12:19:58 pm »
aero housings are L and R specific..
ive got one btw.. its JUST the housing.. none of the hardware or bracketry, but yours should fit just fine.
Reply #8October 01, 2012, 04:34:04 pm
fdnyguy
  • 499
« Reply #8 on: October 01, 2012, 04:34:04 pm »
Thanks, Brother. I'm looking for a quad radiator support and try and go that way, but in the meantime I need to seal that light till the new one comes.
Shame I don't have enough time to head up ur way for a beer on me. Making a right at Sacremento. Maybe next year.
Reply #9October 02, 2012, 10:43:02 am
« Reply #9 on: October 02, 2012, 10:43:02 am »
im only like, oh, 6 hours from Sac... lol.
and im on the same page as you.. looking for a roundie setup, but i never can find them.. looks like i will prolly end up buying new parts..
Reply #10October 03, 2012, 02:23:59 pm
fdnyguy
  • 499
« Reply #10 on: October 03, 2012, 02:23:59 pm »
"Only" 6 hours? lol. Of course, all that driving whats another 6? lol. Maybe I'll check my time schedule and zip on up. But if not , definitely next year. My friends do not have faith in Mk2's like the group here. They think I'm nuts driving a 23 yr old car 8,000 miles across and back. With a new engine by Scott, and much work done by a TDI guru, I am VERY confident it will be ok. Just need ppl to leave phone numbers along my route JUST in case....lol
Reply #11October 03, 2012, 03:11:45 pm
« Reply #11 on: October 03, 2012, 03:11:45 pm »
I have UTMOST trust in my mk2s..
the diesel, having mexican electricals kinda sucks every once in a while, but with the car thief's tool kit (jumper wires, starter button, that sort of thing) i can keep it going..
my 86 GTI, ive driven it for 3+ years now without a single issue that was not related to fuel quality, or water in fuel..
Mechanical fuel injection ROCKS!!!
and i was being sarcastic about the 6 hours from sac to here.. its more like 9 hours. its 6 hours if you are cracked out on rockstar going way faster than the speed limit.. lol.
Reply #12October 03, 2012, 06:03:11 pm
fdnyguy
  • 499
« Reply #12 on: October 03, 2012, 06:03:11 pm »
Well, most guys on here can fix almost anything so trust is not really a factor when you're 800 miles from home.....lol. Going it alone with no skills (but a tool kit), now thats guts. After the issues being taken care of, the car rocks. Still have to get re-adjusted to the 0-60 time of 7 hours and 23 minutes, but once up to speed it holds up great. Haven't had time to open up the air intake, which no doubt will improve it some with the Giles IP, but won't break any speed records. But mileage has improved considerably, and I tend to think once more air is let in, it should get better. A/C works great for the southern route, but in talking with Tyler, the foam insulation has crapped out for the heat. Any help along the way may get you beer.... lol
The car will warm up over time and be comfortable, but that first 20 minutes or so it can be annoying. So the Northern route home may not be a pleasureable experience (but you guys know that). But with the Recaros, it is a blast to drive, and I am glad I not only kept it, but had the work done by people on and off this site. I don't make excuses, but I have tried to fix things, just isn't me, so this car is like a boat :) . So while they may be things on here I don't follow too well (the turbo knowledge here is French to me!), the knowledge, builds, cars and friendships on here makes this one of the best sites for the Mk2, and look forward to the posts every day.
So I will try and seal the beam this week with silicone (any suggestions?), dry it out and put a new bulb in. 10/25 I am heading to the East coast of Florida, then west via Texas and LA/SD.  9 hours from Sacramento, I think i may have to wait till next year, when I do Rt-66, the PCH and zip home via the Trans-Canada Highway. Hell, maybe do it in the Mk2 as well. Though the Canadian Rockies may be a challenge...
Reply #13October 03, 2012, 09:51:43 pm
GTiTDi
  • 153
« Reply #13 on: October 03, 2012, 09:51:43 pm »
OK so I am assuming this is a non-TDI swapped mk2....my zero-60 time is more like 7 seconds than 7 hours! yikes!
Reply #14October 04, 2012, 05:02:10 am
fdnyguy
  • 499
« Reply #14 on: October 04, 2012, 05:02:10 am »
Yes, a 91 1.6 N/A block installed in my 89. Was installed by Scott (ilikevwdiesel), with a Giles IP,Techtronics 1.8 exhaust manifold and d/p and a 2.25" exhaust.  Haven't had time to modify the air intake, and using the original small intake kind of contradicts the use of the above goodies.
After driving my 09 TDI and going back to the N/A, it just isnt the speed demon the other car is. I had more work done to it on and off the engine, and now I am happy with the car. With NYC area stop and go traffic, I averaged 39.8 mpg, and expect more on the open road, especially the flat, level southern route. and as you experts say, once I get more air in I should cut the 0-60 time by at least 4 hours.. :)
