Author Topic: AAZ very short blocks available.  (Read 4130 times)
October 27, 2011, 03:44:53 pm
Henchman
  • 183
« on: October 27, 2011, 03:44:53 pm »
Hi All,
I have a couple of AAZ blocks with rotating assemblies available.  Both were recently running engines, 1 doesn't have the intermediate shaft.  I haven't pulled the crank or pistons yet until I know if people want the block, pan and whatever else is still nailed to it or just the rotating assembly. Both have approx 350-400k km on them.  Both are very clean in the piston/sleeve area.
I'm located in Eastern Ontario Canada, but ship from Ogdensburg, NY several times a week.  If you want block and everything, I will have to figure out shipping freight as these weigh at least 100lbs (probably more like 150lbs).  If your within driving distance, pickup is free or we can meet at some midpoint.
These are sold with a 5 year/5 foot warranty, whichever comes first  ;D!  Seriously though, if you buy the rotating assembly and I pull it and it's not as expected, we can renegociate or cancel the sale.
I also have several AAZ cranks with keyways that range from almost perfect to beat up (the latter would be good for TDI crank pulleys), as well as con-rods and pistons.
Don't ask for pics of the blocks.  They're rusty with 4 dark holes where the pistons are.  If you're serious about cranks or pistons, I can provide pics.
PM me if interested.
Ian
Reply #1September 03, 2012, 03:13:37 pm
paolomarks
  • 146
Re: AAZ very short blocks available.
« Reply #1 on: September 03, 2012, 03:13:37 pm »
Hello,
Do you have a connecting rod out of an AAZ.?  I need one in good condition.  Thanks Paolo.
Reply #2September 06, 2012, 05:22:53 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: September 06, 2012, 05:22:53 pm »
Edited by burn_your_money
No thread-jacking please. Make your own post.
« Last Edit: September 06, 2012, 07:34:18 pm by burn_your_money »
