Author Topic: FS: MK2 CE1 cluster w/ tach, BV block off plate & other.  (Read 4126 times)
May 11, 2008, 07:56:05 pm
Black Smokin' Diesel
  • 656
« on: May 11, 2008, 07:56:05 pm »
-MK2 CE1 cluster with tach (the two plug type) SOLD
-BV block off plate SOLD
-Set of MK2 switches with a blue LED mod. It's the headlight switch, the defrost switch and the heater controls (non-AC). The headlight switch is out of a 87 jetta, CE1, no DRL, 8 pins. LED don't dim like normal bulbs.
This is what they look like
I want 25$ shipped.
-MK2 deep underdash tray, black. Fits non-AC cars only. Pretty mint. 25$ plus shipping
-Passat syncro steering wheel, big spline, perfect shape, 20$ plus shipping.
-87 Jetta 4 button steering wheel, small spline, perfect shape, 15$ plus shipping.
-Scirocco S steering wheel (the three aluminum branch type), small spline almost perfect. Some material missing at the top but nothing visible once installed. The horn ring is screwed to the wheel so the rubber cap has to be installed AFTER the wheel is installed. It's a bit hard to install but totally possible.
Steering wheel in question
Asking 50$ plus shipping
Pics of everything on request. PM prefered.
Reply #1May 11, 2008, 08:04:48 pm
« Reply #1 on: May 11, 2008, 08:04:48 pm »
actually the horn ring pops off of the steering wheel,
Reply #2May 12, 2008, 02:24:00 pm
  • 656
« Reply #2 on: May 12, 2008, 02:24:00 pm »
Quote from: "Trev0rbr"
I know but the clips were all busted so I had to get creative while keeping the horn functionnal.
