Author Topic: AAZ part out - round 2  (Read 4890 times)
May 10, 2008, 05:48:31 pm
« on: May 10, 2008, 05:48:31 pm »
These are a new batch of parts I picked up today.
All these parts were pulled from a scrap yard. I don't know their condition or mileage.
1) AAZ head, complete with valves, cam and cam cover. No injectors. 2 of the plastic caps for the VC nuts are MIA $50
Might be warped, no straight edge. Has the normal cracks between the valves and also a crack at the precup. It was removed using the proper steps. All 4 precups are cracked. One of the precups falls out of the head. No damage to it's bore though. Also, all the pistons had deep mushrooming from valve contact. Strangly all the valves look to be ok visually (while still installed) I`m not sure if someone got lucky, the valves are bent or the belt broke and someone replaced/rebuilt the head.
2) K14 turbo. Excessive shaft play. $50 - SOLD
3) Exhaust manifold - K14, T3, K24 etc $60
4) AAZ intake manifold $60
5) AAZ vacuum pump with hose - $35
Reply #1May 10, 2008, 06:03:16 pm
Fisher
  • 148
K14 Turbo
« Reply #1 on: May 10, 2008, 06:03:16 pm »
I'll take the Turbo if it's a K14.
Rudy
Reply #2May 10, 2008, 06:05:48 pm
« Reply #2 on: May 10, 2008, 06:05:48 pm »
Yes it is
Reply #3May 10, 2008, 07:29:04 pm
KTZed
  • 170
« Reply #3 on: May 10, 2008, 07:29:04 pm »
Do you have the crank breather hose vent thingy that the 1.6 doesnt have?
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #4May 11, 2008, 07:06:29 am
« Reply #4 on: May 11, 2008, 07:06:29 am »
No I don't. I'm looking for one myself
Reply #5May 12, 2008, 07:05:20 pm
« Reply #5 on: May 12, 2008, 07:05:20 pm »
up
Reply #6May 12, 2008, 08:32:16 pm
CaddyWVO
  • 37
intake and exhaust
« Reply #6 on: May 12, 2008, 08:32:16 pm »
I have a 1.9 TD AAZ that was installed in a normally aspirated configuration. Do you still have the exhaust and intake manifolds? If yes, I will take them.
1981 VW Caddy 1.9L TD AAZ
GTI wheels w/R-134AC
Bilstein struts & Neuspeed springs front
Monroe Sensimatics rear
Eurosport upper and lower stress bars
Suspension Technology Anti-Sway front
Reply #7May 12, 2008, 09:08:23 pm
« Reply #7 on: May 12, 2008, 09:08:23 pm »
Quote from: "KTZed"
Is that the hose that attaches to the lower block and goes up to the hockey puck? If so, I have one.
Reply #8May 12, 2008, 10:13:23 pm
KTZed
  • 170
« Reply #8 on: May 12, 2008, 10:13:23 pm »
Quote from: "jimfoo"
Quote from: "KTZed"
Hmmm PM'd so as not to jack thread  :D
Reply #9May 13, 2008, 06:54:59 pm
« Reply #9 on: May 13, 2008, 06:54:59 pm »
IM sent.
 8)
Reply #10May 14, 2008, 05:47:49 pm
« Reply #10 on: May 14, 2008, 05:47:49 pm »
I just checked this head as best I can for warpage and it appears to be straight. I can't gaurantee it because I'm not cleaning it, which is required to get accurate readings.
