Yes i had read that it was borrowed from Malone.since then i have made even better pumps!!when you do send his pump in, pls leave all the settings aloneso i can run it on the Test Stand and measure what fuel you're running to rach that magic 200HP!look forward to new projects too.We're currently working on some TDI nozzles that will flow way morefuel and help the M-TDI projects that allot of people are asking for.Devor is trying to run a big turbo on his and we're running out of fuelwith his stock and modded injectors.i'll keep everyone up to date.Giles
I see,Well thats sounds about right.What were you torque #'s ?
[tīs GT2359V, ~47mm inducer with ~35psi boost. I know Iīm pushing the turbo way over limits, but the engine needs boost to make power :?
Itīs the low end torque that bends rods...
It means that youīll more likely bend rods with small turbo. The lower rpm torque peaks, harder it is for rods. Itīs not the amount of boost itself. Language barrier starts to kick, maybe someone understand and translate it to english :lol:
i believe its the peak cylinder pressure that bends the rods, so unless you're really making power then 25psi should be fine.
Quote from: "MJF"It means that youīll more likely bend rods with small turbo. The lower rpm torque peaks, harder it is for rods. Itīs not the amount of boost itself. Language barrier starts to kick, maybe someone understand and translate it to english :lol:rods dont like power/torque + high revs, the lower the revs, the more the rods like it.aarghhh, i have the same problem mate, i'm running out of words :lol: Greetz, Benjamin
I see,Well thats sounds about right.What were you torque #'s ?What cam plate are you using Dave?I think a 1.6 cam plate with 12 or 14mm head will work better for 5500 +rpm.The extra 1mm lift with the 1.9 camplate may not be neccesary with the bigger head.
Hey DaveI have proven on my Test Stand that if you feed the injection pump withmore than a positive feed then it will increase the dynamic flow of the pumpif you decrease you static timing a bit to compensate for the increasedinternal pressure which will give you more advance earlier on.what static timing do you have it set at now?hope this helps you get over 200try 15 psi firstGiles
