Author Topic: Franken motor!  (Read 151387 times)
Reply #195March 17, 2008, 04:11:02 pm
935racer
Franken motor!
« Reply #195 on: March 17, 2008, 04:11:02 pm »
Just got 30 new injector heat shields, should be on the dyno in 2-3 hours. Will we break 200? :twisted:
Reply #196March 17, 2008, 06:56:07 pm
935racer
Franken motor!
« Reply #196 on: March 17, 2008, 06:56:07 pm »
Epic fail.
Lost 12 whp
I dyno'd 195whp for my base line run today, new injectors maxed me out at 183whp. :evil:
 :roll:
Reply #197March 17, 2008, 07:27:18 pm
subsonic
  • 1836
Franken motor!
« Reply #197 on: March 17, 2008, 07:27:18 pm »
WTF!   :?   How can stock nozzles put out more than these?  Any idea's ?
Reply #198March 17, 2008, 07:30:59 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
What Nozzles
« Reply #198 on: March 17, 2008, 07:30:59 pm »
Hey what nozzles did you install in the other injectors?
send me a PM if you want
Giles
Reply #199March 17, 2008, 07:31:38 pm
Franken motor!
« Reply #199 on: March 17, 2008, 07:31:38 pm »
Is the spray pattern different on the Merc nozzles? Maybe they don't promote the same swirl in a VW. Or the timing changed as a result of them?
Reply #200March 17, 2008, 08:30:46 pm
935racer
Franken motor!
« Reply #200 on: March 17, 2008, 08:30:46 pm »
Video:
http://millerperformancecars.com/car-videos/passenger-performance-jetta.html
Click and save as.
The ones I just put on that made less power were 1.9 injectors with mercedes 300d nozzles, the ones that made 195 (smoothed graph) were stock 1.6td.
The 1.9 injectors do seem to give more fuel, I took it for a drive and my revs were hanging, but but it doesn't pull as hard as the 1.6 nozzles.
What are we going to do to get more fuel Giles? I need way more fuel from 5500 and up.
Reply #201March 17, 2008, 08:39:20 pm
Franken motor!
« Reply #201 on: March 17, 2008, 08:39:20 pm »
love the video!!! sounds like a jet engine when that thing gets going  8)
sucks for the drop in whp though :(
i seem to recall reading about the merc nozzles being designed for a different type of pre-chamber, maybe that has something to do with it? fine for the low end, but lacking on the top end?
Reply #202March 17, 2008, 09:14:13 pm
subsonic
  • 1836
Re: What Nozzles
« Reply #202 on: March 17, 2008, 09:14:13 pm »
Quote from: "Giles@PerformanceDiesel"
Giles
DNO SD261   0 434 250 128
These were installed in AAZ 1.9 dual spring injector bodies.  Pop preasure was set at 155bar.  The first time they have been run since being rebuilt was when Dave installed them for the dyno run.  Nozzles were brand new. Injectors rebuilt by reputable injection shop.
The dual springs were designed to quite the engine down a little right?  I think they let a little fuel through right before the main injection. I don't know if this has anything to do with it.
I think the AAZ injectors were also set at a different pop preasure than the 1.6TD injectors.  Again, not sure if this has any effect on the results.
Would timing need to be changed to compensate for the different injection rate of the dual springs?
I guess if none of the above could be considered factors, you could try swapping the nozzles into the single spring 1.6 bodies.  Process of elimination.
Reply #203March 17, 2008, 09:18:57 pm
1slowvw
Franken motor!
« Reply #203 on: March 17, 2008, 09:18:57 pm »
After watching that vid I am left speechless, the sound is amazing.
I am also curious now as to what effect the merc nozzles would have in the 1.6 body.
Either way you guys should be very pumped(no pun intended), your a real inspiration to us diesel guys who are just at the bottom of the learning curve.
1SlowVW
Reply #204March 17, 2008, 09:27:29 pm
DVST8R
  • 535
Franken motor!
« Reply #204 on: March 17, 2008, 09:27:29 pm »
Quote from: "1slowvw"
1SlowVW
I had the same wondering, the 1.6 nozzles in the 1.9 bodies, and the merc's in the 1.6 bodies. Just for more knowledge.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #205March 17, 2008, 09:32:09 pm
rallydiesel
  • 1880
Franken motor!
« Reply #205 on: March 17, 2008, 09:32:09 pm »
That video is great.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #206March 17, 2008, 09:53:23 pm
subsonic
  • 1836
Franken motor!
« Reply #206 on: March 17, 2008, 09:53:23 pm »
What do you think Giles, about the difference in the injector bodies?
Reply #207March 18, 2008, 12:46:02 am
carrizog60
  • 978
Franken motor!
« Reply #207 on: March 18, 2008, 12:46:02 am »
please try the merc nozzles on 1.6 bodies as i have done the same and am concerned that they didnt give any gains because my turbo cant give more than 1.6 bar...
did you acheived the same pressure?
Portugal
Reply #208March 18, 2008, 02:55:44 am
Benjamin
  • 485
Franken motor!
« Reply #208 on: March 18, 2008, 02:55:44 am »
Quote from: "DVST8R"
I was thinking exactly the same  :D
Greetz, Benjamin
Must make +250hp
Reply #209March 18, 2008, 08:20:47 am
subsonic
  • 1836
Franken motor!
« Reply #209 on: March 18, 2008, 08:20:47 am »
I just got off the phone with Giles.  He also suggested swapping the nozzles into the 1.6 bodies for a run.
As a additional note, he thought there might be the possibility that the 1.9 dual spring injectors have the potential, if performance tuned correctly, to deliver more power.
