#165
by
subsonic
on 01 Mar, 2008 05:53
That does not bode well for me then.
My set up is going to be almost the same as he has. I am going with a smaller turbo, the Merc .48. I guess keeping the boost down is going to be a must. I'll sure be interested in what he finds when he opens it up.
#166
by
on 01 Mar, 2008 06:04
Get your rods polished and heat treated.
#167
by
DVST8R
on 01 Mar, 2008 08:39
Iirc Dave was racing and it was rpm under full load that killed the rod, like 6000+rpm at full load. That merc .48 is a lot smaller then the t3/t4 60trim .63 that Dave is running. Regardless the rod shot peening and polishing would be a good idea, or finding some h-beam 4340 rods would be ideal. Dave is also running main studs.
I would call Dave before you put it together and get his recommendations. Remember this as well the key to the big numbers that Dave got was mostly from the port work in the head. :wink:
#168
by
subsonic
on 01 Mar, 2008 09:25
Yep, I am working with Dave on this. I may end up buying the current intake/exhaust manifolds, DP, and IC plumbing from his setup. I sent him two new 1.9 heads. One for him in trade for him doing the port work on mine. I also have the ARP main studs, head studs and con rod bolts. Pistons should be back from Swain tech this week. I have been looking on line for info on polishing rods. Beside from the links that showed a hot blonde going to work on a guys tool :lol: , the links say it will help. From there, though there appears to be a split. Some said to heat treat, others said to shot peen to return the surface strength. Opinions? Anyone know how much stronger the rod will be? Is it quantifiable?
#169
by
on 01 Mar, 2008 10:05
chrome plate the rods!
#170
by
blkboostedtruck
on 01 Mar, 2008 11:02
Hey Duane, manifold is from my friends over at kinetic motorsports. If you are in need of one this manifold will be for sale soon along with this downpipe because I will be going with a tubular manifold.
ahh that would be great! what populare turbos work with that manifold?
i'd like to get one of your intakes also!
send me a P.M. on what your thinking ?
thanks Duane
subsonic
i thought i was in line for his downpipe and exaust manifold?
well either way let me know whats going on here?
Duane
#171
by
DVST8R
on 01 Mar, 2008 12:39
#172
by
subsonic
on 01 Mar, 2008 15:01
thanks Duane
subsonic
Duane
PM sent.
#173
by
blkboostedtruck
on 01 Mar, 2008 15:17
resolution P.M. sent back to subsonic
#174
by
on 03 Mar, 2008 21:35
i love viggens
#175
by
spencebm
on 05 Mar, 2008 18:42
bump, bump, bump it up, more pics/video
#176
by
Giles@PerformanceDiesel
on 15 Mar, 2008 15:11
Hey guys
Great to see such a powerful project, i haven't heard anything about
the 12 or 14mm head you want me to install?
200WHP is fantastic too.
let me know what else i can do.
Giles
#177
by
DVST8R
on 15 Mar, 2008 16:18
The 14mm head is still sitting all wrapped up and pretty on the shelf. I picked it up held it admired it. Dave said he is saving it for the built bottom end.
At this point we are still trying to work out this setup, and I think that it has enough so that with the bigger injectors it will break 200whp. If we could find those dieselious nozzles, it might have enough for 220whp.
Giles in case you didn't read the whole thread, this is the same pump that you built for Malone almost 3 years ago.
*** I updated this on another thread the H-beam rods thread, but I will update it here too ***
Dave's alternator bracket failed taking out the water pump. It got a little warm, so as a precaution he pulled the head, and everything looks good, NO BENT RODS!!! one valve nicked a piston, but wasn't bent, not sure of the cause as it does have HD valve springs in it, and it was only the one, regardless he cleaned it up and put it back together.
Dave has also Machined an anti surge compressor housing for the T4oE that he is running, and is able to get a full 32psi+ without surge now!! Compared to 24psi ish previously. He has to get a heavier spring in the external gate though as it flutters above 32psi. He is trying to get it on the dyno this weekend with 36psi, and a before and after with the other injectors, this should push it well past the 200whp goal. Keeping my fingers crossed, and wishing I could be down there.
On an aside, Giles I have a Cummins VE pump, that will need to be FULLY worked over here this summer. :wink:
#178
by
zagarus
on 15 Mar, 2008 17:42
dave ill be down at the coast this sunday and monday. Any chance i can pop by to say hello and see this car??
#179
by
subsonic
on 15 Mar, 2008 21:02
I can hear it. Yep, that sounds like some new dyno numbers coming down the road. 210? 215? :twisted:
