Looking good
nice to hear it is up and running
Thanks, Petter! We are very, very happy with the turbo. It was probably a lot more work than an OEM setup, but the results have exceeded our expectations by far. My goal was to build something that would keep up with modern traffic, but the car is actually...dare I say... *fast* now. During yesterday's shakedown run of our new clutch, we were out on a little country road, and a Mk3 GTI caught up to us and got right on our rear bumper. We slowed down and did a couple of accelerations back to the speed limit. The GTI faded away pretty quickly each time. Okay, it was an 8V GTI, but still...
Very sweet!
I love my Holset HE 200, just wish it spooled quicker than 2K for my 5,000 lb van with tall tires (not the turbo's fault),
Maybe I need to turn up the fuel
Thanks! Yeah, thankfully it seems to be a great match for our ~2200 lb Jetta. It spools reasonable quickly (even at altitude), much quicker than the T3/T4 in my 16vt corrado, but I'd call it more of a horsepower setup than a torque setup. The midrange is impressive, but it keeps pulling to redline. Can't wait to get an AAZ head on it...
At first, we were consistently maintaining about 21 psi, but turning up the fuel simply increased our EGTs. I said, "well, I guess that's it". Then I noticed there was a little bit of black smoke under boost, so I disconnected the wastegate. Voila, 24.5 psi with no smoke, and EGTs spiking below 1400 F. I subsequently turned up the fuel a tad, and we're hitting 25-25.5 psi, but occasionally spiking EGT to the high 1400s, so I can't go any higher (EGTs stay in the "safe" range if we shift earlier). Next step will probably be water/alcohol injection to recover some EGT margin, along with ARP studs and a metal HG. Here are the highlights of our current setup:
- Mk2 Jetta 1.6d
- HE200WG
- Cast 8V T25 exhaust manifold, cleaned up and gasket matched.
- G60 intake manifold, also gasket matched
- FMIC
- 2.5" turbo-back exhaust, techtonics over-axle w/ resonator, no rear muffler
- Auber instruments dual-channel gauge w/ EGT and boost
- 9.5 lb flywheel w/ 16V PP
- NA LDA pump, governor mod, modified for boost input, trying to source a stiffer aneroid spring...
This is my first experience with diesels. I have to say it's been a lot of fun.
