Author Topic: aaz turbo option  (Read 55488 times)
Reply #120January 17, 2015, 06:12:05 pm
Mk1 Diesel
  • 5
Re: aaz turbo option
« Reply #120 on: January 17, 2015, 06:12:05 pm »
345nm.to big turbo I tink the 173whp dynoed more nm on smaller Holset
09 Golf 2,0 TDI 4-motion
83 Golf 1,6 TD 204whp Holset he221w, dieselmeken 11mm IP
Rosten rods ,Studs,Girdle ,AWIC ,rebuildt portet and polished head With bigger valves. Now going Compound..
Reply #121January 17, 2015, 11:13:36 pm
Alcaid
  • 549
« Reply #121 on: January 17, 2015, 11:13:36 pm »
That 173whp and 204whp you are talking about its my car :D
Alcaid I tink the 204whp was With Holset HE221wg don't remember, but I tink so ???
PS. my english writing are bad (Norwegians) :P
204whp was with the weird HE221W-5cm with the exact same turbine wheel and just a little bigger comp inducer than the HE200WG and ported shroud compressor housing. Turbine is the limiting factor on this setup so both HE200WG and this HE221W version will be able to do the same 204whp. HE200WG will have slighly better compressor efficiency.
'10 VW Passat 1.6TDI Highline
Reply #122January 18, 2015, 02:22:09 am
mark3kid
  • 80
« Reply #122 on: January 18, 2015, 02:22:09 am »
So where I got the he200wg from you. I should have no issue reaching my goal of at least 180whp
When that turbo hits full boost you will forget all about the work to get you there, I promise It's pretty similar to women giving birth... - Alcaid
Reply #123January 18, 2015, 02:42:44 am
Alcaid
  • 549
« Reply #123 on: January 18, 2015, 02:42:44 am »
180whp - no problem if you have enough fuel ;)
Reply #124January 18, 2015, 06:19:22 am
mark3kid
  • 80
« Reply #124 on: January 18, 2015, 06:19:22 am »
I believe I have 120cc of fuel and that sounds like it should be enough
Reply #125January 18, 2015, 06:28:30 am
mark3kid
  • 80
« Reply #125 on: January 18, 2015, 06:28:30 am »
What is the cc of the stock pump?
Reply #126January 18, 2015, 06:53:18 am
Alcaid
  • 549
« Reply #126 on: January 18, 2015, 06:53:18 am »
120cc is enough, stock untampered pump is 40cc :p
Reply #127January 18, 2015, 04:40:06 pm
mark3kid
  • 80
« Reply #127 on: January 18, 2015, 04:40:06 pm »
Good I'm getting very excited to start working on this again. I'm pretty interested in seeing how much damage is actually done to the motor. It sure wasn't living well last going off. I put around 170kms on it this year so I'm really hopping that this year will be different
Reply #128February 09, 2015, 06:44:24 pm
mark3kid
  • 80
« Reply #128 on: February 09, 2015, 06:44:24 pm »
So guys I think I may have found out why I couldn't make any boost. Its #2 cylinder. The cylinder wall looks bad to. I'll probably have to replace the block to. The rings blew apart when I pushed the piston up.
Reply #129February 09, 2015, 06:46:47 pm
« Reply #129 on: February 09, 2015, 06:46:47 pm »
I do not understand how that happened. Any ideas?
Reply #130February 10, 2015, 08:29:33 am
mark3kid
  • 80
« Reply #130 on: February 10, 2015, 08:29:33 am »
None at all!! Cylinder is cracked to
Reply #131February 10, 2015, 09:37:30 am
« Reply #131 on: February 10, 2015, 09:37:30 am »
that's is extremely unfortunate.
Reply #132February 10, 2015, 09:50:31 am
shelbot
  • 49
« Reply #132 on: February 10, 2015, 09:50:31 am »
I'm going to make a wild guess but would it be possible you had a cracked ring and this is where everything started. Maybe the high temps first started and progressed to get worst with the boost also dropping you were leaking more and more into the crank? Just what I picture going on.
Maple bacon chocolate bar's and seal fat salmon dear jerky. Sooooooo let's build a snowman!
Reply #133February 10, 2015, 09:54:47 am
« Reply #133 on: February 10, 2015, 09:54:47 am »
yeah quite possible, its on the front hotter side of the piston too
Reply #134February 10, 2015, 09:55:06 am
« Reply #134 on: February 10, 2015, 09:55:06 am »
check the injectors
