Ok,so I've got the turbos back on and running.Still not working right but I believe that it may be due to the fact that the engine is running under fueled.On 23 psi now I can hardly get the pyro above 1200 deg,before on 37 psi I could peg the pyro at 1500 by fourth gear :shock:.With the lowered compression and increased cc's in displacment this engine needs more fuel!
I've upgraded the fuel supply pump its the same one that hilfolk'r using form the ISB cummins.I was using the one from a 6.5TD powered chev before and it barely kept up with demand.
Tonight I put brand new mercedes nozzles in place of the GTD ones.The engine runs 25-50 rpm higher cold and hot so I'm sure they are delivering more fuel however its not enough to really notice,possibly 5 hp I'm not sure?
Also directly after that test drive I installed Dave's Stg 3 camshaft from Passenger Preformance.Again I didn't really feel any noticeable gain in preformance,Perhaps a second cut from spool time and mabye 25 deg from egt's.
Because my engine is not fueled properly yet I would say that the gains from both the nozzles and espically the cam have not really been fully seen yet!!
I don't even rev the engine that high right now as its running low on boost with the small T3 set to 23 psi.As soon at 23 psi comes at lower rpm there is'nt much more torque after that.
I'll be working with the inj pump at my work with the asistance of my Boss.Swaping it to 12mm soon as well as some other setup changes while on the test bench.
Oh, and I had to replace my new coolant temp gague as it was a dud(isspro) new one works great though.Also done some body work to the car and got some cheap paint put on :roll:.The other biggest job of all was definitely changing the heater core,If you've changed one for the first time you know what I mean :evil:.
I think thats about all for now
