Author Topic: Compound pics  (Read 147856 times)
Reply #135August 10, 2006, 01:32:38 pm
DVST8R
  • 535
Compound pics
« Reply #135 on: August 10, 2006, 01:32:38 pm »
A P7100 pump is a bosch inline injection pump used on 2nd gen cummins 12V motor's.  :wink:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #136August 12, 2006, 10:07:16 am
hillfolk'r
  • 1532
Compound pics
« Reply #136 on: August 12, 2006, 10:07:16 am »
um,my manifold dude will machine my hx30w housing to fit the hy35 turbo setup,but he would rather machine more than one,for cost purposes
unless i really twist his arm.....
does anyone want a hx30w  exh housing machined to fit a hy35 turbo???
lemme know
sorry to jump off topic just figured id post here,since andy2 has done this
Throttle cables ftw
Reply #137September 30, 2006, 07:30:07 pm
andy2
Compound pics
« Reply #137 on: September 30, 2006, 07:30:07 pm »
Well I fineally got my 12mm pump built,With bone stock advance :wink:  and only full fuel holding on to 4700RPM before my new working governor starts to cut off.However while pumping out 105cc's worth fuel my clutch now slips,Its a 16v(stock Pressure plate) with kevlar faced disc.It held up to 180hp Thats about it.Any clutch suggestions?
Reply #138September 30, 2006, 08:18:33 pm
therabbittree
  • 299
Compound pics
« Reply #138 on: September 30, 2006, 08:18:33 pm »
talk to blake ie :  macs dub or hillfolk. he jsut did a sweet clutch i think it was clutch net or something  pm or email him
thanks
Deo
Reply #139October 01, 2006, 08:00:32 am
Compound pics
« Reply #139 on: October 01, 2006, 08:00:32 am »
blakes was off of clutchnet.com some sorta 4 puck *** and it's the 210 setup too
Reply #140October 07, 2006, 06:56:07 pm
Kantdrive55
  • 65
    • http://www.dieselperformance.com
Compound pics
« Reply #140 on: October 07, 2006, 06:56:07 pm »
Quote from: andy2
  We use Southbend Clutch for the diesel pickups.  They work awesome.  They have some pretty cool stuff for your car as well.  southbendclutch.com
1993 TD Jetta
Cold air intake,pump tweaked,2.5" exhaust and more to come.
Reply #141October 07, 2006, 10:01:39 pm
macsdub
  • 165
Compound pics
« Reply #141 on: October 07, 2006, 10:01:39 pm »
Quote from: Trev0rbr
yep
its a "red" setup
get the red pressure plate,and the 4 puck ceramic
it wont slip then
most of the time this is hilfolk'r... ive forgotten my password
Reply #142October 09, 2006, 08:49:32 am
andy2
Compound pics
« Reply #142 on: October 09, 2006, 08:49:32 am »
Reply #143October 09, 2006, 09:00:52 am
Benjamin
  • 485
Compound pics
« Reply #143 on: October 09, 2006, 09:00:52 am »
the link doenst work andy2
Greetz, Benjamin
Must make +250hp
Reply #144October 09, 2006, 09:44:05 am
andy2
Compound pics
« Reply #144 on: October 09, 2006, 09:44:05 am »
I don't know?Still works for me?Anyone having issues?
Reply #145October 09, 2006, 10:09:31 am
VelocityConservation
  • 92
Link
« Reply #145 on: October 09, 2006, 10:09:31 am »
It is broken for me as well.
90 TD Jetta, NA to TD swap completed '07
Reply #146October 09, 2006, 03:24:00 pm
andy2
Compound pics
« Reply #146 on: October 09, 2006, 03:24:00 pm »
Reply #147October 13, 2006, 11:30:19 am
A2TD
Compound pics
« Reply #147 on: October 13, 2006, 11:30:19 am »
Andy what type of dyno was your car running on????
Reply #148October 13, 2006, 02:54:16 pm
andy2
Compound pics
« Reply #148 on: October 13, 2006, 02:54:16 pm »
The dyno in the link pictured is the actuall one my car was on.
http://www.chandlertechnologies.com/dyno.php
Reply #149October 14, 2006, 12:56:56 am
DVST8R
  • 535
Compound pics
« Reply #149 on: October 14, 2006, 12:56:56 am »
So have you dynoed it since the 12mm pump? did you get your clutch sorted out. I know that Dave @ PP has a 4puck and a 16Vpressure plate that holds alot of power, more then any 020 I have come across. That is if you are still running an 020. If not clutchnet has good stuff so does spec, as well as, dxd (southbends car division). How does the new combonaiton spool, with the big pump?
