Author Topic: Thezorn's AAZ rebuild.  (Read 63491 times)
Reply #105February 19, 2011, 07:19:53 pm
Thezorn
  • 381
Re: Thezorn's AAZ rebuild.
« Reply #105 on: February 19, 2011, 07:19:53 pm »
Updates finally, havent put any pics up ina while so heres a bunch.
Had to deal with this
So I did this, Im not sure what the cap for the vac booster was made of but it was a b**ch to tap. Or maybe my tap was garbage..
Parts parts parts.
ACT Clutch/pressure plate
Tial 38mm wastegate
Aircraftspruce EGT probe
POR15'd Engine bay, half done
Cleaned K14 and K24 / rebuild k24
Lapped the k24 wastegate valve seat.
I decided to try something new. The K14 is going to be externally wastegated so I deciding to cut the wastegate housing off the turbo. This will give me more room for the K24 to fit in there and also more room for the external gate to go.
Just have to weld up the holes, I guess I will see if it was a good idea :P
Engine is all together and painted, Has anyone else used HASTINGS piston rings? they are what my machinist got me.
Also got a new inst. cluster with a tach in it. Is there any way to swap the speedo/odometer assembleys from cluster to cluster so I can keep the milage the same?
That mostley it for now, more to come soon!
« Last Edit: February 19, 2011, 07:23:34 pm by Thezorn »
Compounded 93 AAZ
Reply #106February 20, 2011, 09:35:47 pm
Thezorn
  • 381
« Reply #106 on: February 20, 2011, 09:35:47 pm »
Got the lifters in the head, oil pump in and pan on and a bit more paint done today. I had my camera but luckily my girlfriend had left the sd card for the camera in the computer....or maybe it was me ;D
Tried cleaning the tranny the other day at the car wash but it barely touched the dirt and grim on that thing. What is the best way to clean it?
Im thinking warm water pressure washer and some engine degreaser for my next try.
Compounded 93 AAZ
Reply #107February 20, 2011, 10:01:29 pm
myvolkswagen
  • 96
« Reply #107 on: February 20, 2011, 10:01:29 pm »
Scotts brite pads, super clean, gloves and hours of work. Have fun. It's worth it when you get paint on it
Reply #108February 20, 2011, 11:25:36 pm
Thezorn
  • 381
« Reply #108 on: February 20, 2011, 11:25:36 pm »
My worst fear haha, I guess it has to be done
Compounded 93 AAZ
Reply #109February 21, 2011, 06:13:48 am
« Reply #109 on: February 21, 2011, 06:13:48 am »
I love the black color on yours and the parts of mine that are black. That said I will never paint another thing black on my engine again. I have had an oil leak since the first start and I think I found it last week. You will NEVER be able to tell where fuel, antifreeze, oil, and whatever else can leak out of these is coming from with it black. I love the way it looks, but if I were you and had enough coin for 2 more cans of engine paint I would try to recolor it :D
Reply #110February 21, 2011, 11:01:16 am
Thezorn
  • 381
« Reply #110 on: February 21, 2011, 11:01:16 am »
GHAAA, you dont know how many times I have heard that haha. I think ill run to the hardware store today and snag another colour.
Compounded 93 AAZ
Reply #111February 21, 2011, 07:47:34 pm
ktownboostn
  • 31
« Reply #111 on: February 21, 2011, 07:47:34 pm »
Wow !! watching this one forsure !!
2001 VW Jetta 24v VR6 - Rally Car
1990 VW Jetta AAZ/MF - Daily coal roller
1986 VW Cabriolet 12v VR6 - Project car
Reply #112February 21, 2011, 09:54:35 pm
Thezorn
  • 381
« Reply #112 on: February 21, 2011, 09:54:35 pm »
The little rubber bit there is a check valve.  I suspect that without it you'll end up with crankcase oil/mist getting sucked into your brake booster and possibly wreck the booster diaphragm.  Might take quite some time, tho.  Also, I hope that you made sure that the threads of the new fitting didn't protrude below the surface of the top plate and you didn't leave any burr on the hole.  In either case, the vanes of the vac pump will get trashed.  I recently got a brass check valve from McMaster and installed it into one vac pump that had the nipple broken off.  I haven't installed and tested it, tho.
Yea I was thinking about that but ive been told that it works fine to do this, and my local dealer cant get me a new one so this was my only option. I made sure the threads of the brass fitting arent poking through also.
I ended up painting a grey "oil leak detection" strip around the head to block sealling area, since ive been razzed about it more then a few times ;D
Compounded 93 AAZ
Reply #113February 22, 2011, 12:30:49 pm
Thezorn
  • 381
« Reply #113 on: February 22, 2011, 12:30:49 pm »
Please report back if/when your brake booster fails in the next year or two.
Will do, thanks
Compounded 93 AAZ
Reply #114March 22, 2011, 10:58:28 pm
Thezorn
  • 381
« Reply #114 on: March 22, 2011, 10:58:28 pm »
Havent had any updates for a while so here are some pics.
This is how the engine sits till I get a welder in the next few days hopefully
Found a link on vortex that said a mk4 cabin filter/housing was "plug and play" with mk3s so I gave it a try.
Sure enough it fits like a glove
Planing on relocating the PS reservior to here:
to free up some space for the intercooler pipes
Transmision got a well deserved face lift.
Started to tackle some of the rust that inhabited my floor
And the oil pressure guage and new cluster with a Tach I picked up from forum members:
I was searching forever for replacements for the crappy stock cluster lights and finally came across "super bright LED.com"
They sell the tiny twist style bulbs that we need for our clusters and they actually work great, they are super bright haha!!
Thats It for now, will have more soon hopefully, when I get a welder in my possesion.
Compounded 93 AAZ
Reply #115April 01, 2011, 01:08:01 pm
Thezorn
  • 381
« Reply #115 on: April 01, 2011, 01:08:01 pm »
This is how it sits right now, still have to put the wastegate on and figure out where my air filter is going to go.
Compounded 93 AAZ
Reply #116May 07, 2011, 12:53:50 am
Thezorn
  • 381
« Reply #116 on: May 07, 2011, 12:53:50 am »
Good news, got the engine running today after scrtching my head for about an hour finally realizing I have the fuel cut-off switch wire mixed up with the other guy.
One question. I replaced my inst. cluster that originally had a clock in it to one that has a tach. in it. The tach doesnt work. Im guessing this is beacuse my car doesnt have the wire coming from the "w" terminal to the inst. cluster harness built into it, since it came with a clock.
All I should need to do is run the wire to the right number pin in the harness correct?
Only problem ive had so far is the fuel filter spitting out a ton or air... it will get fixed tomorrow though.
Compounded 93 AAZ
Reply #117May 07, 2011, 01:25:47 am
zagarus
  • 619
« Reply #117 on: May 07, 2011, 01:25:47 am »
how have I missed this build! twin turbo setup looks amazing!
Reply #118May 07, 2011, 10:30:28 am
Thezorn
  • 381
« Reply #118 on: May 07, 2011, 10:30:28 am »
haha thanks, hopefully it runs well too. It will be insured and going for its first drive this afternoon.
Compounded 93 AAZ
Reply #119May 07, 2011, 10:19:32 pm
RadoTD
  • 513
    Stage WTF
« Reply #119 on: May 07, 2011, 10:19:32 pm »
Sweet! Can't wait to hear how yours runs!
You're correct about the W terminal... mine was a black/red wire coming off of the alternator. I've got mine run straight to the cluster harness (U1/06) skipping the fuse box
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
