Author Topic: Thezorn's AAZ rebuild.  (Read 65159 times)
Reply #120May 08, 2011, 01:44:12 am
Thezorn
  • 381
Re: Thezorn's AAZ rebuild.
« Reply #120 on: May 08, 2011, 01:44:12 am »
You're correct about the W terminal... mine was a black/red wire coming off of the alternator. I've got mine run straight to the cluster harness (U1/06) skipping the fuse box
Okay cool, thats what I figured.
Ill see if I can get a video tomorrow. Only thing im having problems with now is that my fuel filter is spitting out tones of air. I remember reading something about how the return line plastic thingy has something to do with air getting into the system.
Just to be sure I changed the lines that got between the tank hard lines and the fuel filter with clear fuel line to make sure that no air was getting into the system there, luckily none is. Could it be that the filter still isnt full of fuel? It was about half empty when I stored it..
But the engine has ran enough for me to think that the filter should be full of fuel by now?
You guys have any ideas?
Compounded 93 AAZ
Reply #121May 08, 2011, 09:22:35 pm
Thezorn
  • 381
« Reply #121 on: May 08, 2011, 09:22:35 pm »
Sweet! Can't wait to hear how yours runs!
Do you remember off hand what if you had to splice it into and exsisting wire in the harness? or was the little slot in the harness empty?
Im having troubles getting the tach to work.
Compounded 93 AAZ
Reply #122May 08, 2011, 09:29:13 pm
RadoTD
  • 513
    Stage WTF
« Reply #122 on: May 08, 2011, 09:29:13 pm »
See the PM, and I just spliced it into the wire coming from the fuse box to the cluster, there was a wire already there
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #123May 10, 2011, 10:36:24 am
« Reply #123 on: May 10, 2011, 10:36:24 am »
If your filter has the plastic tee on top that the return lines pass through then that'd be where I start looking.  Problem #1 is they can crack / leak / fail to seat properly on the filter.  The retaining clip isn't particularly brilliant in my opinion and probably has a fair bit to do with problems.  You can try slathering some vaseline all over the seal and then putting it back on, purely for testing though.  The diesel will dissolve the vaseline pretty quickly.
Problem #2 is that it is a recirculating valve, so any air that DOES get in there will continue to get circulated back to the filter again until the fuel temperature gets high enough to close the valve.  Total PITA.
My advise would be to replace your filter with one that doesn't have that feature - the '85 filter seems to be the one:
http://parts.autopartsonlinecanada.com/parts/apocanada/wizard.jsp?year=1985&make=VW&model=JET-D-001&category=E&part=Fuel+Filter
Then just connect the return lines together.  No more air circulating!
Reply #124May 10, 2011, 10:40:17 am
« Reply #124 on: May 10, 2011, 10:40:17 am »
This is how it sits right now, still have to put the wastegate on and figure out where my air filter is going to go.
 :o TWINS!
Reply #125May 10, 2011, 12:41:08 pm
Thezorn
  • 381
« Reply #125 on: May 10, 2011, 12:41:08 pm »
Perfect Ill try and source one of those badboys locally today, thanks.
Compounded 93 AAZ
Reply #126May 11, 2011, 02:00:52 am
baldone
« Reply #126 on: May 11, 2011, 02:00:52 am »
Twint turbo :o :o :o
Reply #127May 13, 2011, 12:32:28 pm
Thezorn
  • 381
« Reply #127 on: May 13, 2011, 12:32:28 pm »
 :o TWINS!
Compounds :P
On a side note, the turbo was puking out oil from the exhaust side since I had it on a slant and completely forgot that it was going to leak. Sooo..Engine came back out after about 30 mins of cursing and calling myself an Idiot. Got it mostley figured now, Had to make a new motor mount and bracket. Hopefully have it all back in and going today.
But if it leaks oil again....anyone want a free car?
Compounded 93 AAZ
Reply #128May 13, 2011, 12:39:15 pm
trav1856
  • 230
« Reply #128 on: May 13, 2011, 12:39:15 pm »
Free car you say? *perk*
1981 Rabbit Diesel
1981 Cabriolet
Reply #129May 13, 2011, 12:47:59 pm
rallydiesel
  • 1880
« Reply #129 on: May 13, 2011, 12:47:59 pm »
If it's not leaking then it must be low on oil.  :P
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #130May 13, 2011, 01:23:44 pm
RadoTD
  • 513
    Stage WTF
« Reply #130 on: May 13, 2011, 01:23:44 pm »
Oil leaks are just your car marking it's territory!
Reply #131May 13, 2011, 04:40:53 pm
J Z
  • 42
    Sweden
« Reply #131 on: May 13, 2011, 04:40:53 pm »
I prefer to call it ''slowly changing oil'' instead of ''oil leakage''  :)
'75 Volvo 242 D24 TIC
'90 Golf II 1,9 GTD
'91 Golf II 1,9 M-TDI
Reply #132May 13, 2011, 05:05:25 pm
Thezorn
  • 381
« Reply #132 on: May 13, 2011, 05:05:25 pm »
Hahah yea I think thats how its gunna be!
Its almost all back together. Ill get some pics of the motor mount and such if I can later.
Compounded 93 AAZ
Reply #133May 17, 2011, 07:28:39 pm
Thezorn
  • 381
« Reply #133 on: May 17, 2011, 07:28:39 pm »
Well, there is still a few oil leaks I need to deal with.. Somehow forgot the oil filter housing gasket when it was all going back together ???
Also having problems with the oil drain for the second turbo. How high is the oil level supposed to be in the pan when its full? My drain bung is pretty well as high as it can be on the pan but It is still somehow under the oil level. The oil flows fine for like 2 minutes while the engine runs but then it seems like once the drain line fills up it starts to back up into the turbo and leak out of the exhaust side into the DP.
It alsmost seems like its creating some sort of sump though. When I check my dip stick it is right at the lowest notch.
I think I might try and hook the drain up to the hole in the block that the K14 is draining into and see if that makes a difference..?
What do you guys think?
Im sorta scratching my head at this point.
Compounded 93 AAZ
Reply #134May 17, 2011, 09:59:29 pm
RadoTD
  • 513
    Stage WTF
« Reply #134 on: May 17, 2011, 09:59:29 pm »
That's weird...
My bung is below the oil level as well, but I haven't had any problems with it backing up the line. What size return line are you running and does it run over the CV or under it? If it's running over the CV with a 90deg fitting, you might be getting backed up at that fitting
