Author Topic: Timing tools for 1.9 aaz  (Read 2059 times)
August 20, 2009, 08:40:05 am
Henchman
  • 183
« on: August 20, 2009, 08:40:05 am »
Hi All,
Can anyone tell me if this kit on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380142846001&viewitem=&_trkparms=tab%3DWatching  would do for a timing belt change?  Is is more than I need or perfect if I can afford it?
Thanks for the input!
Ian
Reply #1August 20, 2009, 10:42:28 am
Re: Timing tools for 1.9 aaz
« Reply #1 on: August 20, 2009, 10:42:28 am »
thats EVERYTHING YOU NEED to do the job right.
Reply #2August 20, 2009, 06:29:32 pm
« Reply #2 on: August 20, 2009, 06:29:32 pm »
That depends. If your pump has the 2 piece pulley you don't need any of that fancy stuff. All you need is a 6mm drill bit (or SAE equivilant), and a flat bar to lock the camshaft.
Reply #3August 21, 2009, 09:28:47 am
Henchman
  • 183
« Reply #3 on: August 21, 2009, 09:28:47 am »
I believe I have a 2 piece pulley.  Pulley bolts to flat circular plate that is held on by a bolt/woodruff?  Is this the method where you lock it down and mark all the pulleys/belt and reassemble witht the new belt and all the marks in the same place?  I have read that this can be difficult and that keeping everything lined up is difficult.
Opinions?
Ian
Reply #4August 21, 2009, 12:59:55 pm
« Reply #4 on: August 21, 2009, 12:59:55 pm »
no, the 2 piece pulley is the one thats super easy. you dont have to hardly time *** that way, just make sure the cam is where its supposed to be. you take the 4 bolts off the pulley and take it off that way, then you dont have to un-time anything.
