Timing tools for 1.9 aaz
Topic: Timing tools for 1.9 aaz (Read 2048 times)
August 20, 2009, 08:40:05 am
Henchman
August 20, 2009, 08:40:05 am »
Hi All,
Can anyone tell me if this kit on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380142846001&viewitem=&_trkparms=tab%3DWatching
would do for a timing belt change? Is is more than I need or perfect if I can afford it?
Thanks for the input!
Ian
Under way - 1991 Passat Syncro Wagon w/m-tdi
1991 Passat GL Wagon w/AAZ conversion (now using engine/tranny from 1993 Passat
1993 Passat GL 1.9 Diesel (RIP 385k km, engine, tranny, clutch all original)
August 20, 2009, 10:42:28 am
Re: Timing tools for 1.9 aaz
August 20, 2009, 10:42:28 am »
thats EVERYTHING YOU NEED to do the job right.
August 20, 2009, 06:29:32 pm
August 20, 2009, 06:29:32 pm »
That depends. If your pump has the 2 piece pulley you don't need any of that fancy stuff. All you need is a 6mm drill bit (or SAE equivilant), and a flat bar to lock the camshaft.
August 21, 2009, 09:28:47 am
Henchman
August 21, 2009, 09:28:47 am »
I believe I have a 2 piece pulley. Pulley bolts to flat circular plate that is held on by a bolt/woodruff? Is this the method where you lock it down and mark all the pulleys/belt and reassemble witht the new belt and all the marks in the same place? I have read that this can be difficult and that keeping everything lined up is difficult.
Opinions?
Ian
August 21, 2009, 12:59:55 pm
August 21, 2009, 12:59:55 pm »
no, the 2 piece pulley is the one thats super easy. you dont have to hardly time *** that way, just make sure the cam is where its supposed to be. you take the 4 bolts off the pulley and take it off that way, then you dont have to un-time anything.
