Author Topic: Franken motor!  (Read 150969 times)
Reply #150February 04, 2008, 06:27:37 pm
935racer
Franken motor!
« Reply #150 on: February 04, 2008, 06:27:37 pm »
Quote from: "zagarus"
So Dave with this new shop expect to see me sometime this summer wanting a dyno run  :D
Sounds about right 8)
No accel times yet as my clutch is slipping in 1st-3rd gears under hard acceleration. After the o2a goes in I'll get some 1/4 mile runs and 0-60mph.
Reply #151February 27, 2008, 01:34:57 pm
euglen
  • 6
Franken motor!
« Reply #151 on: February 27, 2008, 01:34:57 pm »
935racer nice work :shock:  did You used 1,9 head with 1,9 or  1,6 camshaft?
Reply #152February 27, 2008, 02:01:44 pm
Franken motor!
« Reply #152 on: February 27, 2008, 02:01:44 pm »
Quote from: "rallydiesel"
I'd be interested to see if jimfoo can reach some nice hp/tq if his AAZ/1Z hybrid works out. A 1.9 m-TDI in a Mk2 would be my dream car.
Unfortunately I'm, not going for big power as my tranny can't handle much over 150, if even that. So you'll have to wait for the next aaz to tdi conversion. :lol:
Reply #153February 28, 2008, 08:33:11 am
DVST8R
  • 535
Franken motor!
« Reply #153 on: February 28, 2008, 08:33:11 am »
Quote from: "euglen"
Iirc it's a 1.6 camshaft, as that is all he had around at the time.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #154February 28, 2008, 11:20:30 am
Benjamin
  • 485
Franken motor!
« Reply #154 on: February 28, 2008, 11:20:30 am »
very nice!!!
i've been away from this board for some time, but i definitely was missing some!
Greetz, Benjamin
Must make +250hp
Reply #155February 28, 2008, 02:08:16 pm
spencebm
  • 686
Franken motor!
« Reply #155 on: February 28, 2008, 02:08:16 pm »
please get a video up!!  i need to hear this beast on the dyno or open road, please!!!!!!!!!
Ben Spencer
Reply #156February 28, 2008, 06:27:19 pm
JetPo
Franken motor!
« Reply #156 on: February 28, 2008, 06:27:19 pm »
Quote from: "spencebm"
PLEASE !!!  :twisted:
Reply #157February 29, 2008, 08:09:07 am
DVST8R
  • 535
Franken motor!
« Reply #157 on: February 29, 2008, 08:09:07 am »
I had a chance to ride in it, last weekend. It is a MONSTER, we hit 200km/h+ no problem and was still pulling hard when Dave let out, this was only 22psi, as he was having some other boost issues at the normal 28psi that is usually run. It drives around off boost about as quick as a stock TD with boost. Perfectly comfortable for daily driving. I'm sure once Dave gets all moved in and caught up with his orders he will make a video. There are still a few more tweeks that need to be done. Cam, exhaust mani, and probably a different turbo as this one surges bad past 28psi. Dave and I both suspect at least one bent rod as well. This would hold true for approx hp with Andy2's findings when he bent his rods as well.
Reply #158February 29, 2008, 09:46:49 am
subsonic
  • 1836
Franken motor!
« Reply #158 on: February 29, 2008, 09:46:49 am »
Toss in those 1.9 injectors with the merc nozzles :twisted:
Reply #159February 29, 2008, 12:44:20 pm
spencebm
  • 686
Franken motor!
« Reply #159 on: February 29, 2008, 12:44:20 pm »
take that rod out and just grab it and bend it back into shape, throw it back in their and turn up the pump! :wink:
Ben Spencer
Reply #160February 29, 2008, 12:46:25 pm
spencebm
  • 686
Franken motor!
« Reply #160 on: February 29, 2008, 12:46:25 pm »
zagarus, how do you keep all that black smoke off your back end?
Ben Spencer
Reply #161February 29, 2008, 01:52:55 pm
DVST8R
  • 535
Franken motor!
« Reply #161 on: February 29, 2008, 01:52:55 pm »
Quote from: "subsonic"
We are still trying to find the custom one off dieselious nozzles, that Jake (fspgtd) had made up, Mark (Malone) bought for the original franken motor, and were lost some where in the old shop. Those with some 1.9 bodies should give it at least 220hp worth of fuel.
Reply #162February 29, 2008, 01:54:27 pm
DVST8R
  • 535
Franken motor!
« Reply #162 on: February 29, 2008, 01:54:27 pm »
LOL I think Dave will just keep rocking it till it blows up or till he builds his 1.7 bottom end. That pump is turned right to the end of its life, to the point it hangs at high rpm!
Reply #163February 29, 2008, 09:15:14 pm
subsonic
  • 1836
Franken motor!
« Reply #163 on: February 29, 2008, 09:15:14 pm »
If a rod did get bent, are you guys thinking of replacing them with something else?  I have not seen many other options for the 1.6.
Reply #164February 29, 2008, 09:26:58 pm
DVST8R
  • 535
Franken motor!
« Reply #164 on: February 29, 2008, 09:26:58 pm »
I think Dave will run it till it blows, or till he gets together a built 1.7 bottom end. The 1.7 will have custom rods, pistons, the whole shebang.
