Author Topic: Seeking comments on using a 1.6 TD inj pump on an AAZ motor  (Read 2397 times)
July 13, 2007, 11:40:15 pm
bigblockchev
  • 271
I'm wondering if I would be better off to replace my tired AAZ inj pump (it's an Ecodiesel too) with a pump from a 1.6TD rather than getting the AAZ pump rebuilt. Anyone have any experience good or bad with this situation. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #1July 14, 2007, 12:49:22 pm
steel-jaw-sasha
  • 9
    • http://homepage.mac.com/keithsasha/
« Reply #1 on: July 14, 2007, 12:49:22 pm »
don't fit I believe the shaft size is different the best mod if you have the two pump is to use the top off the 1.6 pump on the 1.9 pump. Giving you more boost fuel etc.
SJS
Reply #2July 14, 2007, 01:01:01 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #2 on: July 14, 2007, 01:01:01 pm »
it'll work, but you need to put all the 1.6L bracketry on the engine. Can't remember if the serpentine belt bracketry will mate with it without mods. You might also need to put the AAZ pump's delivery valves into the 1.6L pump.
Reply #3July 15, 2007, 01:57:15 pm
bigblockchev
  • 271
« Reply #3 on: July 15, 2007, 01:57:15 pm »
bump for more comments
2000 Jetta TDI
