Right now I have the actuator blocked off. I just disconeccted the vacume line. Makes a bit more boost but only 2-3 psi more. Today it seems like I have a boost leak so I'm going to look into that. It is running really rough at idle so I also need to look into that.
How much pre-tention do I put on the waste gate?
I'm just wondering if anyone has this turbo mounted up to a trapazoidal flange? Pics?If I mount mine like that my cold side hits my PD intake.
Needless to say, we're extremely happy w/ the Holset -- the car is a blast to drive. I'm thinking about replacing the T3/T04e on my Corrado w/ an HX35 or HE3xx series.
I like your idea of getting rid of the acient T3/T04e and replacing it with a Holset, funny thing is the bigger ones are priced close to the small HE200/211 ones. On E85 a HX35 can give you a ***load of whp!
If anything you can probably get better performance by reducing the boost a little given your low EGT numbers. You've got more air than you need right now. Knock it down to say 28 PSI and I bet your EGTs will barely be over 1250 but you'll reduce the back pressure on your engine.
I used a T25 manifold instead.
Quote from: vanbcguy on December 10, 2014, 07:55:33 amIf anything you can probably get better performance by reducing the boost a little given your low EGT numbers. You've got more air than you need right now. Knock it down to say 28 PSI and I bet your EGTs will barely be over 1250 but you'll reduce the back pressure on your engine.Yeah, that's about where our EGT was when we were troubleshooting a boost leak and running about 29 psi. By your recommendation to reduce boost to get better performance, I assume you believe we're losing efficiency at that pressure ratio. Based on our elevation and boost, our pressure ratio is really high -- about 3.75-3.8 -- which is at the upper limit of the HE200 compressor maps I've seen. You might be right.I'm thinking an upgrade to larger valves (or an AAZ head) is our next step. Honestly, this car runs so well, I don't think that's going to happen anytime soon.
