Author Topic: Bolt needed  (Read 7286 times)
May 27, 2013, 08:17:59 am
One_punchmachinegun
  • 261
Bolt needed
« on: May 27, 2013, 08:17:59 am »
Hey guys, Just bought a mk2 1.6 n/a and it needs a little love. But pretty sure pump timing is off, but before im able to adjust it I need the REAR injection pump bolt and nut. For some reason it doesn't have one. I Know that if I loosen the front three the tension on the T-Belt will loosen.
So does any one have a spare rear injection pump bolt and nut. please let me know ASAP.
Thank you
Tim
的f anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1May 27, 2013, 08:29:28 am
damac
  • 531
Re: Bolt needed
« Reply #1 on: May 27, 2013, 08:29:28 am »
The one underneath?
There is a bolt from the right and on the underside to the left there should be a cone shaped nut that is special.
I would definately get that on the car, but you can adjust pump timing still if you just crack the other enough to be able to smack the pump body with a mallet slightly.
Sadly I don't have one to give you, they are all mated up to blocks on the shelf :(
1985 turbo diesel jetta
Reply #2May 27, 2013, 08:32:36 am
One_punchmachinegun
  • 261
Re:
« Reply #2 on: May 27, 2013, 08:32:36 am »
Yea the one on the underside of the right side of the pump. The one with the special nut.
Sent from my HTC One X using Tapatalk 4 Beta
Reply #3May 27, 2013, 08:48:21 am
bbob203
  • 1789
Re: Bolt needed
« Reply #3 on: May 27, 2013, 08:48:21 am »
they are still available.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4May 27, 2013, 09:09:03 am
One_punchmachinegun
  • 261
Re: Bolt needed
« Reply #4 on: May 27, 2013, 09:09:03 am »
from where?
Reply #5May 27, 2013, 12:39:23 pm
bbob203
  • 1789
Re: Bolt needed
« Reply #5 on: May 27, 2013, 12:39:23 pm »
Try jim ellis vw parts or a dealer. If not i can probably get one for sure at my local vw shop.
03 Jetta wagon TDi
Reply #6May 27, 2013, 01:12:09 pm
One_punchmachinegun
  • 261
Re: Re: Bolt needed
« Reply #6 on: May 27, 2013, 01:12:09 pm »
Ok will try that, thanks.
Sent from my HTC One X using Tapatalk 2
Reply #7May 27, 2013, 01:44:33 pm
Re: Bolt needed
« Reply #7 on: May 27, 2013, 01:44:33 pm »
bbob should have 1 from his 1.6na he took apart here as i told him to not loose it..
Reply #8May 27, 2013, 03:45:01 pm
One_punchmachinegun
  • 261
Re:
« Reply #8 on: May 27, 2013, 03:45:01 pm »
Bbob..... Are you holding out
Reply #9May 27, 2013, 05:44:35 pm
bbob203
  • 1789
Re: Bolt needed
« Reply #9 on: May 27, 2013, 05:44:35 pm »
If you can't get one thru dealer or I can't get one at vw shop I will sell mine
 I'm out of town right now so I can't even confirm that I have one
03 Jetta wagon TDi
Reply #10May 27, 2013, 07:30:20 pm
Re: Bolt needed
« Reply #10 on: May 27, 2013, 07:30:20 pm »
Ive used a linger bolt with a washer and nut to get me by for a while.
Reply #11May 27, 2013, 07:38:12 pm
One_punchmachinegun
  • 261
Re: Re: Bolt needed
« Reply #11 on: May 27, 2013, 07:38:12 pm »
I was thinking about something like that... We'll see I'll be giving the dealer ship a call tomorrow
Reply #12May 27, 2013, 09:50:01 pm
Gizmoman
  • 1301
Re: Bolt needed
« Reply #12 on: May 27, 2013, 09:50:01 pm »
Take an old bolt and cut the head off so it fits into your drill.
Put a nut on it, then another so the last one is flush with the end of the bolt.
Now run the drill Double-nutted bolt) up against a grinder wheel and round-er off!
I went to buy one from a fore mentioned site and they want 16 bucks for the silly thing!.
Reply #13May 28, 2013, 05:07:11 am
One_punchmachinegun
  • 261
Re: Re: Bolt needed
« Reply #13 on: May 28, 2013, 05:07:11 am »
I will try that. Seems simple and straight forward. Buy your going to want a longer nut right? A standard nut seems short to use.
Reply #14May 28, 2013, 06:23:09 am
Gizmoman
  • 1301
Re: Bolt needed
« Reply #14 on: May 28, 2013, 06:23:09 am »
Finding a longer nut could be difficult - may as well spend 16 bucks at Jim Ellis.
Just a standard one will work. I don't think it needs to be as fully radiused (is that a word) as the stock nut. I think the concept is to get it to lock-in/center when you tighten it. For the price, it's worth a shot. ;D
