Author Topic: 1.6TD out of a Quantum  (Read 6410 times)
June 19, 2012, 08:09:21 am
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« on: June 19, 2012, 08:09:21 am »
Hey everyone, not sure where to post this but here it goes.
Last weekend me and a friend picked up a 79 Audi Fox for him to restore. The guy selling it to him had planned on doing a 1.6TD swap from a quantum, with the quantum 5spd diesel transaxle. The engine has been sitting for a while, and seems to be all complete.
Question I have is, once I turn it over a few times by hand to make sure it is free, what should I do before attempting to start it?
I was planning on filling the IP, hooking up the feed and return lines, hooking up the battery, energizing the Fuel shutoff solenoid, the glowplugs momentarily, and starting it up. Anything else I should do as to avoid unneccesary wear and tear on the engine? I realize there could be some surface rust in places I can't see, but nothing to be worried about I assume.
Any input would be welcome.
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #1June 19, 2012, 08:33:51 am
Re: 1.6TD out of a Quantum
« Reply #1 on: June 19, 2012, 08:33:51 am »
Fully inspect the timing belt. Check the oil. You can remove the vacuum pump and spin the oil pump to pre-lube the engine without actually needing to turn the engine over.
Reply #2June 19, 2012, 09:16:04 am
GTiTDi
  • 153
« Reply #2 on: June 19, 2012, 09:16:04 am »
Good idea, that is one of my favorite early style block tricks! Here is what I use accomplish that...
[/url]
[/img]
this and an electric drill!
Reply #3June 19, 2012, 10:36:58 am
« Reply #3 on: June 19, 2012, 10:36:58 am »
Looks good, I usually just use a 12 or 13mm socket
Reply #4June 20, 2012, 11:01:34 am
flyingscott
  • 1
« Reply #4 on: June 20, 2012, 11:01:34 am »
Thanks for posting this GTiTDi.
For now the Fox is fine without the TD and 5 speed, but I can't wait to start working on the swap. Here are some pictures of the TD and 5 speed, and of the fox it will be going in.
Reply #5June 20, 2012, 01:41:39 pm
Wayland
  • 364
« Reply #5 on: June 20, 2012, 01:41:39 pm »
FYI, you'll have to modify the trans tunnel a bit to get the 5 speed to fit in. Nothing major, but just something to consider.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #6June 20, 2012, 02:57:22 pm
GTiTDi
  • 153
« Reply #6 on: June 20, 2012, 02:57:22 pm »
Thanks for that reminder! I recall the seller telling us it would need a bit of "massaging" with a sledge hammer to make it fit! That is a pretty standard part of VW/Audi swaps lol! I had to bash in the frame rail to get the 1Z into my mk2 GTI
Reply #7June 20, 2012, 05:27:29 pm
flowmastergfunk
  • 129
« Reply #7 on: June 20, 2012, 05:27:29 pm »
This will be a sweet build! That fox looks clean! All that bracketry on the backside of the motor looks like a clustered mess to me though! Is that a generator instead of an alternator? That is the first time I have seen one of these motors with that layout!
Reply #8June 20, 2012, 07:01:56 pm
« Reply #8 on: June 20, 2012, 07:01:56 pm »
longitudinal engines use QUITE DIFFERENT looking alternators, from what is used on any transverse setup.. it looks just like the alternator used on my audi TD5 engine..
Reply #9June 22, 2012, 12:41:36 pm
« Reply #9 on: June 22, 2012, 12:41:36 pm »
That old Audi looks so cool, a definite head turner.
It irks me that they're FWD though.
Reply #10June 22, 2012, 12:50:41 pm
« Reply #10 on: June 22, 2012, 12:50:41 pm »
with VW/Audi, you primarily get FWD, or AWD.. not too many RWD cars built after the a/c beetles..
Reply #11June 22, 2012, 02:22:51 pm
GTiTDi
  • 153
« Reply #11 on: June 22, 2012, 02:22:51 pm »
This is a generator not commonly used after prehistoric times (the sixties)
This is an alternator
Alternators are much larger in diameter and usually have an aluminum case.
Reply #12June 22, 2012, 08:56:43 pm
flowmastergfunk
  • 129
« Reply #12 on: June 22, 2012, 08:56:43 pm »
That is exactly my point! It looks like a generator to me! If you look right above the A/C compressor, that looks more like a generator than an alternator!! No fins or anything! I thought dinosaurs only had those too. That is why I was shocked to even ponder that there might be one on a newer car. I might be young and naive but I have never seen an alternator with no fins. What is the final verdict?
     Just because of the aesthetics of this motor, my personal taste would drive me to delete the A/C and power steering just to clean up those belts and find a more convenient spot for an alternator. I am turned off by all the mess that is posted by the exhaust. Seeing the motor turned "the right way" makes me wish that it was really RWD. Those setups are misleading! I am still very interested to see where this build goes!
Reply #13June 22, 2012, 11:21:21 pm
Wayland
  • 364
« Reply #13 on: June 22, 2012, 11:21:21 pm »
It does have fins. It's a plastic fan, rather than steel, so the fins are smaller and enclosed at the front. If you look carefully you can see it.
93 Dodge CTD Truck
Reply #14June 23, 2012, 12:58:43 am
VW Smokr
  • 114
« Reply #14 on: June 23, 2012, 12:58:43 am »
One caveat for the QTD engine assy... look into the entry of the Quantum downpipe & notice that it's constricted internally (a ring or some such is welded in there), causing turbulence & cutting down at least a third of the flow capacity. That can be eliminated for quicker turbo spool-up & a more free-flowing exhaust. Ideal is supposed to be a 2.25-to-3"(or 3.5)" megaphone effect from the turbo back in the first 12 inches, and continuing at 3-3.5" for about 3ft or so, then gradually cut down to 2.5-3" for the rest of the way back to a low backpressure  muffler (if you choose to run a muffler).
VW must have put that contriction in there to hold down total boost, max RPMs, or something re. warranty. It can't be optimum for performance or MPG. My 2 cents worth.
J.R.
SoCal
